Yeah,
Lots of stress on the body when you're putting out 1000hp....especially in an older & fragile R32 chassis.
Chances are the panel gaps will get warped.
To achieve 1000hp with an RB20, you're going to need to stroke out the block to 2.4L (go with I-BEAM conrods as they can be lighter yet attain the same strength as a heavier H-Beam) and cement fill the block for high boost application,then strap on twin HKS GT3040 turbines, convert to solid lifters, full E85 conversion and fuel system to suit, modify the cylinder head as necessary (including a set of drag spec camshafts) and optimise port design etc etc, and lots of other stuff.
Done.
Thanks been waiting on this answer.
Will exclude the cement fill XD.
Edited by JDM_R32_R35
lol at euro being monopoly money.
HAVE YOU SEEN SHITTY AUS DOLLARS?
IMO admin should set up the site so that when people write "negative nancy" it auto changes to "negative plattsy" like it does with 'kunt' and 'flammin mongrel'
i like this. +1 for this idea.
also shit post should be "an ianjb" from now on. :woot:
No worries.
Cement fill is likely to be necessary for a 1000hp RB20. It is called "block filler".
It gives the block more rigidity, as at high power output the cylinder liners will experience distortion while you're laying down the power (e.g. as they are surrounded by areas which actually can be considered a weak area - e.g. water jacket).
You can still run water cooled setup if you fill the block to the top row of frost plugs. But for best support you would block fill it completely to the top, but you won't be able to run water cooled anymore.
No worries.
if you don't, will it create seal gaps?
  • Like 1
In all seriouseness Jem did a 540 kw rb 20 once but it was running nos to spool the stupidly large turbo and then it exploded on the line at the drags from memory
If I don't the liners will just crack?
I was thinking without nos.
He was serious about the cement, its definitely required.
I am using CNC liners as well really need for the cement?
hard Bloc helps stop the bore walls flexing out under power stroke allowing pressure to bypass piston
thanks
wtf is a cnc liner?
I meant bore wall
Helps overall rigidity also which is a big variable when talking 1000hp.
Grout/cement filled block will be a must.
+1
that to, I've seen how much a 26 block twists with 700hp, can only imagine how much a 20 block does with 1000+hp
I think ip has watched too many youtube videos on cnc lathes
Op I can sell you one start at 80k
Ppl are overestimating this.............
80k?? AU or EU???
You are not obliged to reply.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
