no...but it does make spark plug changes sooooo much easier :rofl:
hell yeah, depending on the particular intake / car some other stuff may have to be moved around (battery??)to accomodate the repositioned tb
but it would be worth it just for the better accesss to plugs/ignition coils
When the AUD was trading at USD55c and Greddy and Nismo plenums were extremely expensive a cut and shut might have made sense to someone.
Today you can buy a buckchoy front facing plenum for a round of drinks.
hopefully the quality will have improved with time, id be annoyed if i spent hours fitting up a china intake just to have the bastard leak on me
It's not mines but I got the picture online. The one below is my friend car. Rb25. He literally beats his car. Drifting, burning out and he also daily the car. No problems so far. 3rd year it's like that
Did he notice significant or any improvement at all?
Maybe we need a pro and cons list.
pros
less pipe work
easier to change plugs
cons
unknown effect on air distribution
better chance of a defect
then it's just a matter of weighing it up.
  • Like 1
I guess the best way is if someone goes on dyno with normal plenum and then does the C&S job and see difference. Highly doubt there would be any volunteers.
I also add to SUPERBEN's con list that it could lean cylinders out although we have no proof of this thus far
sigh.
Don't worry mate, I agree with your sentiments exactly.
If people want to screw up their cylinder balance that's their prerogative. It is just a big flashing RUN AWAY sign if I see a car like that, I instantly know the owner has taken many other shortcuts.
Mostly I just feel sorry for the car. Nissans deserve better.
but bro, my mate Habib said it would be fully sik and give me 20kw more powah!
how can you argue with THAT.
but bro, a bunch of internet people just told me it wouldn't work with no factual evidence to back up their claims..
how can you argue with that?
reading through some toyota forums and they have the same arguments on there about the old 7m intake and the jz ffp...now it looks to me the JZ just put the throttle body on the front of the plenum...there was no dramatic changes to the runners or anything its all the same shit...but the TB is on the front now....maybe they realized it makes no difference whatsoever where the TB is when the charge supplied is under pressure...Thats what a plenum is for to accumulate and store the intake charge..the cylinders will then suck in what they need, when they need it..maybe it would make a difference on a NA that has to draw the air in itself..but a boosted car has a plenum full of boosted air...there is plenty there for everyone...
now i imagine the internet theorists are now saying but the forced air is getting pushed to the back cylinders more which is causing it to lean out there...but by that theory one would have to assume the stock design is just forcing more air into the middle cylinders in which case the end cylinders would still be leaning out
So while I do agree it looks like balls...I'm not convinced it is a bad idea.....its just an ugly one and we have all been balls deep in an ugly one before..
  • Like 1
I think thats the most plausible response on the topic thus far
The only down fall I see with a cut & shut is the way the air travels. If looking a stock manifold from the side, it makes a flow able loop from TB to head ports. No hard hitting junctions. When I see the cut & shut manifold, I see the air damning in the back before it starts making a loop around. Looks like extra work for the air flow. I think the Greddy version helped with that hiccup while gaining air volume for less restriction. But then again it still rams the back. If you also compare to Honda motors which are insanely mechanical marvels making a 100hp per liter N/A, it has the same style of engineering as a Greddy style manifold from factory. Just my thoughts. It does seem like a lot of work though to gain easier access to the plugs and coils. But I must admit it does look unique. First time I've seen that to be honest. But that is what is so cool about this engineering stuff with motors, it just might work better than a Greddy. It'd be awesome if someone had some dyno tests done between the different styles. Low, mid, and high end lost or gains.
agree with this 100 percent..funny as..maybe its not worth doing..i agree with that....will it lean out cylinders..i highly doubt it, have a funny feeling you
have more problems with tapered plenums in that regard, but i have no factual evidence to back that up
cheers
darren
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
