Im looking at getting some swaybars for the 32gtst. it is becoming a track car, not a drifter, so i want to buy the right ones.
Selby looks good as i can order what i want.
However i dont know what to order.
Obviously blade adjustable, but what sizes front and rear for a good balance?
I know this subject has been covered (yes i searched a lot), but its basic info, for street use, and whiteline are different to selby.
I dont know if theres anything else relevant. Silvers neomax suspension, solid cradle bushes(thats another question, change? what to?), hicas gone, adjustable this and that.
Thanks.
https://www.sau.com.au/forums/topic/430436-r32-gtst-swaybars/
It's not hard. For really stiff result, put 27 adjustable on the front, 24 adjustable on the rear. You'll probably end up with the front one adjusted away from full stiff and the rear one at max stiffness. For less of a max stifness effort, 24 adjustable front and rear, with the rear probably set to the softer end and the front at the stiffer end. Although those recommendations will really be affected by the relative spring rates.
Realistically, unless you are a race team with budget, you cannot make this "correct" with just one setup anyway. Some will argue that the right way to set up suspension for the circuit is to use the lightest bars you can. The bars are just used for tuning the handling balance. The overall roll resistance is obtained by selecting stiff arse springs. But even then that's a hassle, because bumpy tracks and smooth tracks require different compromises between spring and ani-roll bars (note there's no such thing as a swaybar on a car that's not towing a trailer). And driver preference has a lot to do with it too. You may have two cars in the same team (so the same technical backup on both, with the same engineer) and the two drivers might end up with opposite spring/bar setups and still set similar times. Make them swap cars and they will both go slower.
Yes ill always be a noob racer, but im getting enjoyment from messing with my car. you know what i mean. ;)
So 27 f 24 r is a good all round starting point
Ok, basically in general front stiffer than rear
Right?
haha good point....the quality has never quite been the same since they started manufacturing offshore :(
from memory Roy had some trouble with whiteline bars on this 32
correct, he went to Cuscos.
Nope, and sometimes onshore they would measure from the wrong side of the bar bwahahaha
Yuh, my experience mirrors the above. Front and rear 24mm bars just fell onto my R32. Only hassle with the rear one was it would have helped me to get the car further off the ground before starting work! Granted, I had to put the chassis mount bushes for the front bar onto the wire wheel to remove enough material to make them fit into the D brackets, but I don't take that sort of obstacle seriously.
Sorry to hijack thread but also interested in getting some sway bars down the track..
No drifting.. :)
Question is, how can I identify what sway bars are already ON the car? They look stock to me and can't find any markings.
Edit: Maybe get some vernier calliper's and measure how thick they are?
Edited by Zrobe
You can just measure the thickness, but that might not tell the whole story. The stock front bars on R32s are hollow, hence they are much lighter than a similar sized solid and also somewhat less stiff than a similar sized solid. It is not possible to know exactly how thick the walls are on these hollow bars though, so it's not possible to calculate hoe stiff they are relative to a different sized aftermarket bar. If you have or can make a rig to test how stiff they are then you can compare them. Making such a rig is not super difficult, it's just a lot more work than most people are willing to put into it.
FWIW, my (originally) auto R32 (also a 1993) had a 16mm solid rear and a 22mm hollow front.
Okay, no worries thanks heaps.
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
