Can anyone shed some light on what the next steps should be?
I was thinking
-hook up jumper leads and do another test.
-pull off the timing cover and check the belt
Then if stinky comes around this week.
-Try a new VCT unit just in case if he has one.
Anything else?
yes that is what I would do.
Redo the compression test while hooked to a running engine by jumper leads
When stinkypoo drops by, swap the ignitor, CAS, AFM and ECU (one by one) and see if it makes a difference.
If still crappy results and no luck, take the timing cover off.
Timing cover is like...3 bolts isn't it? The upper half of it at least. It'd take no time to pull off and look at the belt, should be blindingly obvious if that's the problem lol.
I'd check the things that take the least time to do first.
true. I'm not sure how much work it is on a stock 25...on a 26 it needs CAS off, water line disconnected (possible re-bleed) and then about 3 bolts. not a big deal. You should either carefully mark the CAS position before removing it, or redo the base timing after.
Yeah so I can't swap out an ECU which is a bit of a pain because its a nistune R32 ECU.
Using the Window switch (Not the jaycar one) its the proper window switch.
Checked that last night and it seems fine.
Rob pulled out the ecu and re connected just to be sure.
Yeah I will re run the test tonight hopefully ( is it okay to use a jump start pack thing?)
If it's easy to pull the cover off then I will check that as well.
Hopefully stinky has time to stand in the dark and cold with me and try a CAS or maybe even see something I am not noticing.
Daniel - pm your addy and I'll drop around a fully charged Battery, a Jump Pack and Jumper leads after work.
Edit: Oh and a battery charger :)
If tonight was like last night maybe drop off a few jumpers as well :P
LONG LIVE THE RB!
So I had a few of the locals come around tonight. Shout out to "Stinky Poo, Sinister & Wilderboy"
They brought along a jump starter and we decided to do another comp test with a starter pack giving it power.
Cyl 1 = 95
Cyl 2 = 90
Cyl 3 = 80
Cyl 4 = 105
Cyl 5 = 95
Cyl 6 = 100
Sat around and pondered the idea about costs doing an engine swap or just giving up on the dream
But Stinky Poo (Don't want to f**k up the spelling to your real name) Decided he wanted to put it back together and give it one more chance.
We put everything back in and back together and the farken bitch started first go!
Didn't even miss a beat!
Right now I'm left scratching my head as to why the compression is still so low (could it be possibly the tester itself?)
and left wondering why the car just decided to start again for no reason.
Leaves me worried I'm going to get stranded somewhere I don't want to be.
My next step is maybe take it to a workshop for them to triple check everything.
  • Like 1
Thanks to everyone for all the help over the past few days!!
I really really really can't thank you all enough!
Glad this didn't make it to page 10
Long live the RB!
And yes a warm/hot test will be a good comparison because it can be lower when cold right?
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
