Hi all , if your sick of fuel pumps threads go elsewhere .
As many know I've been searching and asking about suitable E85 EFI fuel pumps for road use and from what I've read/heard pumps like Bosch 044s Nismos may not live long lives because ethanol doesn't lubricate like petrol does . I like the Nismo R33 GTR pump but it's a lot of money to throw at a pump that may wear out in a few years .
The E85 pump that keeps popping up is this Walbro F90000267 which is a turbine pump and it's said to be very quiet .
At 450 lpm it's not short of flow though too much can be a problem fuel heat wise .
The other thing is that these pumps have the ability to drag high current at higher fuel pressures and this has caused problems at the tank lid terminals (R33) . Insight sells a gadget to get wiring into fuel tanks and I'll ask Scott about that one .
Is anyone here using this fuel pump and do you get fuel heating issues ?
A .
I have personally installed 5 or 6 of them, and sold many more without any complaints. They are almost silent if installed correctly, more so than the old 255's, and are specifically designed for e85 use. It's a no brainer imo, as I am sure many people have told you already.
Yes the fuel gets hot after a few hours on the dyno, but how is that the fault of the pump? It's the rail that is hot, why don't you look at super cooling the rail with liquid nitrogen or something. :P
Do you need the massive flow? Haven't used these specifically, but the likes of DW300 fuel pumps are quite fine with ethanol - quiet and all that good stuff and probably more suited to the amount of flow you need.
Walbro in-tank is $165, on a 45% off special - so normally easily over NZD$200: http://www.nzperformance.co.nz/fuel-system/walbro-fuel-pumps.html
But even then only $55 (~30%) more than:
http://www.nzperformance.co.nz/deatschwerks-fuel-pumps/dw300-intank-fuel-pump.html
Both are NZD$300 normal price.
Great price on the 300 there, much cheaper than my supplier, but then they never did like buying them in for me.
I sell the e85 Walbro's for $200, why would you bother with anything else at that price, especially if you plan to run ethanol at any percentage.
Very minor mods needed.
As in.. soldering.
Having had the fun of putting an 040, 044, GTR, DW301, and now the Walbro 460LPH pump, I can say they're all of equal difficulty to fit, and the DW300 and Walbro 460LPH pump are both equally quiet (silent compared the rest)
As in.. soldering.
I needed to modify my stock cradle to fit the pump in tank, as the 460LPH pump is too big to fit in the same position. But again, very minor stuff, took 5 minutes.
Greg I'd like to hear your opinions of the DW301 and the Walbro 460 Ethanol pumps .
This is a thread from NASIOC that has the performance data for the DW301 .
http://forums.nasioc.com/forums/showthread.php?t=2102897
It sounds like a good thing and DW seems to have gone all out SAE testing them on E100 .
I like the 13.5v table figures and if not pushing more than about 60 psi the current draw should be easy on an elec system with adequate wiring .
There is a fitting kit to suit their 240SX and this may make it virtually an easy install on a GTS25Ts bracket .
I had a look at the standard wiring in my R33 since the back seat was out and the wire size is not brilliant , it's really small at the FPCM plug .
Thanks for the tip Lith , cheers A .
Edited by discopotato03
The solution? Your questioning it. Looking for ways around it. Just search, see what the eons have done before you. E85 is so well covered these days its not funny. Drop in a big in tank, silent, easy to install, no fuss pump. Oh wait, you want to make a diamond from dogshit. Go right ahead.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
