Hey guys,
I have a strange issue with my RB25DET. It seems to have a weird fluttering/wooshing sound when coming on boost, a lot louder than normal. It seems to build and hold boost ok, maybe a little laggier than usual. I'm thinking maybe a boost leak, but here's the spanner in the works: the weird wooshing sound disappears during medium-hard left turns?? How weird is that? Does anyone know what could cause this issue and why it disappears during left turns only???
Any help appreciated. Thanks.
https://www.sau.com.au/forums/topic/430790-weird-boost-issue-help/
After the sound got worse I eventually found the problem - broken stud where the dump bolts to the turbo, letting a heap of exhaust through the gap. Now I have a worse situation than a boost leak, the stud is broken inside of the turbo exhaust housing and I need some way to get it out...Preferably without removing the turbo >_>
Trust me - I had the same problem last year... Take your turbo out and take it to a thread doctor or machinest... If you do it yourselves I can guarantee you'll ruin it.
Try removing the turbo yourself - if you need help just post on here and I'm sure you'll get plenty of help!
There are many brands. Just go into any hardware or auto parts store and see what they sell. Loctite do one, as do many other big brands. We use one at work with graphite in it and it seems to work well (although it's a bit messy). I have a can of stuff somewhere that I got when I was working at an exhaust shop that we used to use there which worked well too. If I can find it I'll post up what it is.
Thanks for the info.
The thing is, I can go and buy another brand, but if it works just as well as WD40, is there any point in paying more for it (if it costs more)? Hopefully the other brands can provide a stronger product, or one that lubricates better.
The graphite stuff sounds good.
Wd40 is only really a water dispersant and thin oil. It has very little in the way of actual lubricating properties. You can find some friction test videos on YouTube. If you search "friction master wd40" on YouTube there is a 2:36 long video of a test between protecta spray (which I've used and it's pretty good) and wd40. Protecta also have a video on YouTube doing the same test with more oils. I know the guy doing the protecta video and he told me about some other lubes that performed well on the test (almost to the level of protecta), but they didn't show them for obvious reasons. They were bicycle chain lubes though, so not much use for anything else.
Fyi, I am in no way affiliated with protecta.
And using some sort of grease or anti-seize paste when installing things certainly makes life easier in the long run.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
