Was changing my spark plugs yesterday, when the cap on this pipe snapped off. I didn't have time to find a replacement, so I just electrical taped it back on (blue electrical tape in the photo)
Anyone know what it is, and where i can get a new cap for it so it's not held on dodgily by tape lol.
I think it's been on there for so long, that it hardened and just snapped of whilst i was getting all fiddly with the spark plug change.
cheers!
https://www.sau.com.au/forums/topic/430824-whats-this/
Original BOV return.
Yep this!
As we suggest in 99% of threads i would be getting a plumb back BOV and fitting it as even cops that have no training in mechanical knowledge will still know too look for a shiny BOV and will have no hesitation slapping you with a defect!
https://www.sau.com.au/forums/topic/430824-whats-this/#findComment-6987633
As GTSBoy said, while you have a ATMO Bov, the return pipe is not needed.
You can;
A) Buy some heater hose/silicon hose the same diameter and a welsh plug to bung in the end and tighten up the hose with hose clamps or
B) Same as above but if you cannot find a welsh plug a coke bottle lid works perfect or
C) I think Bunnings sell like a "rubber cap" which you put on the bottom of table legs to stop them gauging into wooden floor, not sure if they have the size you need (that's what I would the the original one on yours is)
https://www.sau.com.au/forums/topic/430824-whats-this/#findComment-6987637
Thanks for the fast responses guys.
Any particular plumb back BOV's you can recommend? The atmo one came with the car when i bought it, so I've never really touched it.
Also, what's involved in installing one? Just replacing my atmo with a regular BOV (straight bolt on replacement?) and then a pipe connecting from the BOV to the return that's been blocked off in my photo?
https://www.sau.com.au/forums/topic/430824-whats-this/#findComment-6987646
It really is as simple as that mate!
I have a GFB Respons on mine and its good enough, i used to run the GFB stealth as it was a direct bolt on for the factory spot on the GTT, to be honest though stock will do just fine!
Or you can put a GTR one on for the flutterz lol
https://www.sau.com.au/forums/topic/430824-whats-this/#findComment-6987651
Tried having a quick search, but can't really find one.
Where did you get yours from?
Gonna be tough to find mine came with my valve. Check around on ebay and gumtree find someone selling that bov and if they have the adapter to sell it to you. Or if you know anyone who can weld ask them to make you one. Shouldnt be hard at all.
https://www.sau.com.au/forums/topic/430824-whats-this/#findComment-6988043
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
