As the title states im looking for a clutch to go on my r32, its having a 25 conversion soon and im looking to get this power, what clutch do people recomend? I will be doing the 25 box conversion soon, but using the rb20 box for the mean time, yes i know its not ideal, but it has to do until i get one. It will be a street car, with the going to the track when i can and the usual skid around "industrial areas"
I did try a search before but didnt find what i was looking for.
https://www.sau.com.au/forums/topic/430838-clutch-for-300kw/
City driving pussyfooting 300kw? or actually driving the car hard 300kw? id personally go an ORC or OS GIKEN twin plate sprung centre for a very long clutch life (unless you drive like a pig and clutch the absolute hell out of it) or ring jim berry. OR if you dont want to spend that amount of dough and arent planning to drive the car to its limits for extended peroids.. flick through the exedy catalogue or xtreme.
  • 3 weeks later...
I have a 1996 GTST putting out 276rwkw aiming to get it to 340+ rwkw
using NPC metal button clutch ,engagement of clutch is quite aggressive
been advised by NPC it should handle 650+ Hp
When I first did my engine (273rwkw) I got an Extreme Extra HD clutch (as was suggested by the workshop, as I found out later only because they had a 'deal' with them) - the thing was horrible. So bloody heavy you needed a tree trunk of a leg to even depress the thing, and after about 6-9 months of, let's say 'spirited' use on the street, the thing decided to weld itself to the flywheel one day - I managed to get it off again but after that it carried on like you wouldn't believe (not surprisingly), grinding and making noise etc. Suffice to say, never again will I own an Extreme clutch!
I ripped it out and after reading some very good things rang Jim Berry (i'm in Adelaide) and organised (after a mammoth phone call) for him to rebuild it using the existing pressure plate and organic plate, and have it shipped down here to my workshop. Now, I may be the only person to have a bad story about Jim Berry, but when the clutch arrived, it didn't fit! It went into the car, but it wouldn't disengage completely, and you could barely get it into gear. So out it came, and back to Jim it went, only to comeback a week or so later, and guess what? Not fit again! Jim was totally bemused by this, as were my mechanics, and as the issue dragged on and my car sat in the workshop (and this is my daily drive!) useless, I got pretty annoyed! Third time lucky? Nope. Still wouldn't fit. Finally we gave up, Jim refunded the money and cost of the time wasted (very good of him) and the workshop put in an Exedy heavy duty cushion button ceramic.
Now 2 years later and running E85, making 300rwkw and driving the thing pretty hard (although no track time) the Exedy hasn't missed a beat. The thing grips like you wouldn't believe, so it took a bit of getting used to, especially since it feels (from memory) no heavier than the OEM clutch. Bear in mind though with a ceramic clutch it is pretty on/off - if you release it SUPER slow through the friction point you can take off pretty smoothly, but if you're not paying attention for a moment and let it out without enough revs it will jump your arse forward pretty violently and stall! Now that I'm used to it though it's great to drive, and holds my power easily. The only other annoyance of a ceramic clutch is not being able to ride it at all - especially trying to reverse uphill - after a few seconds of slip the thing will start to grind pretty badly - however it's fine again as soon as it cools down after a moment or two.
The fun thing is trying to watch what I like to call a 'normal' person jump in and try to take off with it - usually results in a number of stalls and some laughs from me.. ;-)
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
