The covers are only the magnet, not the actuator which is behind it. Nissan will want to rebuild the timing chain and tensioner assemblies and replace the cam actuators, this will cost 5-6k or more.
I have found a way to replace the actuators in the VQ25/VQ30 without removal of the engine, but I doubt any mechanic would try such a complex task. Your engine has intake and exhaust actuators which doubles the chances of an issue.
Apparently they think it is not a major job - but off course, seeing i believing, especially when it comes to Nissan.
Cars just back from Nissan. This other branch seems to be very familiar with this problem. From their previous findings, this problem must be software as they have even replaced with a brand new engine on another Skyline v36 and the problem still persists. Put it point blank - THIS IS A NISSAN DESIGN ISSUE.
They also sort of know that there is a software update that can solve this issue, but Nissan Japan won't release to NZ !!
I have read that for the Infinity's in the USA - software update did solve it permanently.
Btw, I have just tried the exhaust relearn procedure and this reduces this problem slightly.
Anyone knows how to update software without Nissan's help?
EXHAUST VALVE TIMING CONTROL LEARNING - Without CONSULT-III
1. Start engine and warm it up to normal operating temperature.
2. Set selector lever to N position (A/T) or neutral position (M/T) and confirm that following electrical or
mechanical loads are not applied.
- Headlamp switch is OFF
- Air conditioner switch is OFF
- Rear defogger switch is OFF
- Steering wheel is in the straight-ahead position, etc.
3. Keep the engine speed between 1,800 and 2,000 rpm at 20 seconds.
Had mine in Nissan today, I gave them a small list of things to check but after they read this thread they decided not to bother further diagnostics.
They think it is a timing issue, or the firmware. One of the staff there has imported the same v36 (still on the boat) and is attempting to get the firmware file from Japan.
I think perhaps the only way I'm going to get this update is to buy a ECU which has already been flashed. A importer I spoke to yesterday says they
have 3x 2008 Sedans comming in 2 weeks and they'd be happy to swap the ecu over for a test.
No clue how to check current version though??
On another note, I turned the car off and unplugged those magnetic retarder sensors once the problem popped up. The problem immediately went away and my car
drove perfectly for the 30 or so meters. I turned it off again, then plugged the sensors back in and the problem was there straight away.
Nissan tell me these sensors only control the advanced position timing (name?) not the crucial timing.
It sounded like a feature the car could live without, but Nissan would not answer the question "Can I drive forever without it?"
Edited by awsam
With an engine light up? I don't think it's wise. Plus you will lose many powerz in the midrange. :P
It is just the cam retarders, are they making noise? If so, can you pinpoint which one is doing it?
Nissan can test and re-tune the cams using Consult3 or 3+, the cams drift around all over the place constantly from my experience, but once they hone in on a degree setting (using the PWM signal to the magnet) they hold it very well. They are self learning to a degree.
Something as simple as the wrong grade of oil could cause these cam issues I suspect, do you know what oil is in it?
I haven't heard any unusual noise, next time it happens I will unplug only one of the sensors and see if that isolates it further.
Nah no clue, what ever oil Wilall Racing use when servicing. But it was doing it well before they serviced it.
I'll have to call them this week and ask about the re-tune, I dare say they'll be very reluctant.
Does anyone know if the ECU needs to be in the car for an upgrade? or can it just be plugged into a power course and flashed? I say this as it may be less trouble to fly to Melb cheap with my ecu and visit Infiniti.
I found a very detailed thread on the 350z exhibiting the exact same issue. Which they confirm is VTC
http://my350z.com/forum/maintenance-and-repair/307878-sputtering-during-warm-up-38.html
Edited by awsam
  • 1 month later...
None yet, still waiting for a response from Infiniti Melb to see if they can get the update.
If not then i'll just have to trade it at a car yard, because there's no hiding the fault so no one would buy it privately :(
Did you ever try cleaning your throttle body?
I've owned a few cars in the past with a similar issue and found the throttle body dirty with carbon deposits and gum.
Works wonders and simple to do.
If i remember correctly from previous post, you bought this car from a dealer, i would say go back to them and let them trade it in less the normal depreciation of time you have owned it.
Yeh I did in Sydney and drove it back to Adelaide.
Is that something I can actually do? Like by law? I've been meaning to look into how strict lemon laws are. Does it really matter that I've had the car since March?
wow great thread and lots of information.
i think i will hold off on purchasing my v36 sedan until someone confirms with nissan/inifiti regarding a permanent fix for this, rather than just unplugging which may cause long term issues.
Awsam, yes you should be covered under ACCC laws as it is deemed a major fault as it has a problem that would have stopped you from buying it if you'd known about it, and it is unsafe as it can cause accidents at traffic lights when taking off.
http://www.accc.gov.au/consumers/consumer-rights-guarantees/repair-replace-refund
if the dealer doesn't play ball, don't get upset or emotional, just give ACCC a call to lodge a complaint and they will give you advice on what to do next.
same :)
I'm doing some asking around as well... hopefully we can find a local specialist
just a thought, have you guys tried adjusting your idle RPM when in D higher? such as 1100-1200 instead of 850.
As i noticed alot of autos idle higher than manuals (which are generally 7-900rpm)
as it appears to be happening at low RPM on take off only, unless you guys mean lowish rpm = under 3000rpm..
This is the way to go, im just surprised you have lived with this problem as long as you have, if it was me i would be there the day i found such faults.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
