  • Replies 118
758-GQZ were the plates , there are pics of the car on the first page..
if i personally find him , i will stab him in the throat , no actually i dont want blood on the car , i dont care about him knowing where i live , I will not let this fiend get away with it..
Thanks again
Maty
Like others have said, dont chase him... you could encourage himto do something stupid and hit anyone or anything endangering other people....i dont care about him but its other people that worry me... :(
Follow from distance... and try and get an idea of where he continues to go and you can wait for him and hopefully get the cops to intercept him....
Cops wont think your a hero if they catch you in a high speed persuit with him so watch out.... :(
Same thing happened to a friend of mine. Seriously fellars, there is no reason why he should know that you are following him. I mean if he were driving on the street, there would be all sorts of normal cars on the road. like lancers, falcadores, magnas.... if it was a skyline following, i'd understand.
Everytime anyone chases him, and he gets away, the chances get worse. He will get more intimidated, and be more scared to drive it out. I believe that you have a decent chance to get the car back.
If anyone sees it, stay a few cars back. Just watch where it goes. Wait till he stops, then do whatever you have to.
With my friend's car, it just so happened that he was followed into a shopping centre carpark. they waited until he went in to buy somehting. While they called people to come quick. When he got back, they had about 5 people on to him.
The important thing, is to stay back, don't let him know u r following, and don't let him get away again.
sorry if this post was long, but it just ****s me off so bad when some dickhead shit****s do things like this, because we look after our cars so bad, and then to think that it could just be gone tomorrow.
ALARMS
About alarms, i've got an autowatch immobilised alarm. The siren is backup battery, but the alarm itself isn't. If I pull the battery, the siren will go off until it runs outta battery, then it'll stop. If I plug the batt back in,it will not start until I disarm the alarm.
Is this good? If it is, you can pick one up for around $170 and aorund 150$ install.
But the thing i'm thinking, is I put it in myself. what use is an alarm, if anyone with a bitta car knowledge can just pull the alarm off from the ignition wiring, and just connect them. Almost all alarm people just put the alarm under the plastic far behind the steering wheel
any advice?
hope u get the car back mate. I'm in sydney, if i was in brissy, i'd be driving around helping you to find.
stickied for ya Maty...
good luck in finding it, I can't believe this fckhead is driving it around??? obviously not a prof thief, more like a joy rider pushing his luck!
Shell,
Dont forget when URMINE was stolen the guys drove it around for a while and were spotted numerous times. Paul had a for sale sticker on it and actually had calls from people aobut it after it was stolen.
Best of luck in finding this car. As has been said, chasing it will do nothing other than scare the theif further and potentially place others in danger. Follow it at a safe distance, ring the police and everyone you know and play it cool.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
