Mugabetown - Whoretownin' At It's Worst.
is that the full on drag car with a HKS T62?
you cant compare that thing to nicks car, thats just unfair.
We cant legitimately compare. but we can use it to troll Nick.
Nick will say its faster....for now, and be all mysterious and shit and we will all go back to not caring
i reckon. so now i will spend half my life driving to the southside to see everyone.
luck of the draw for the rental applications i submitted. this one went through first and time was running out so i had to take it.
the real pisser is going to be driving from Paddington to Sherwood and then to the Mater every Tuesday morning to take mum for chemo...
So what ur saying is, it's ok for your motor to change something to allow much more air into the engine but it's not ok in my case.... Hmm
How did I say that? Stock turbo, stock injectors, unopened motor. Good tuning, good sum of OEM parts :)
No.... If u haven't noticed I'm never happy unless I'm annoying someone else
This appears to be true...
Northside peeps aren't too bad, well most of us anyway :) That drive would be a dampener tho...
That does suck mate, wishing you and your mum the best BTW
welcome to the cool side of town. Need a hand on the weekend?
..... For now
But no seriously my car will never run an 8 that's mental
Thanks Smelly :P
You will have to come around for a drink and say hello sometime and prove that y'all aren't such a bad sort.
Thanks Andy. She went for her first treatment today but had an allergic reaction and is still there. Was meant to be a quick 3 hour session. :(
cool, this fact remains to be seen. Umm....I should be alright for moving I think but thank you for the offer.
Thanks Smelly :P
Shit. That sucks re: allergic reaction.
If you need a hand with anything, let me know. :)
I'm going to throw it out there that Mike's old Z would eat your abomination on the strip. And I think that he may have spend a little less on his car overall as well :P
That's not a fair fight, and to be honnest, I don't think I would have spent less lol
least nick doesnt need to take the engine out to swap his plugs tho.....
I am getting the biggest urge to single the unicorn, though with defects going the way they are perhaps I would be better off staying twins and putting the stock air box back in.
Hmm *ponders*
Since when is fair a conceivable option when dealing with Nick? He brings us down to his level and beats us with experience.
That my friend, is not fair :P
Thanks Smelly :P
Sucks about the reaction!!!
Haha knew it wouldn't be long until someone called me Smelly! We are gathering at Z German Club thursday night if you wish to come, there will be some of us north siders there :)
She was actually lhao at you via PM... Ouch
I must learn not to subconciously send PM's always gets me in trouble...
By anthing he also means more than happy to drink beers, just incase you thought he may be the not drinking kind...
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
