Mugabetown - Whoretownin' At It's Worst.
Not sure first time its ever done it. Then later it fluttered between 3000-3500 with no actual rev loss to motor. :/ Strange. Didn't play up at happy laps.
dry joints in the tacho can do it.
if you are decent at soldering, redo all the solder joints in the tacho.
Cleaning the injectors could just add to the problem.. The ECU is doing it because another sensor is out.. have you reset the ECU, clean AFM and make sure you don't have a air leak or atmosphere bov..
Could be fuel reg?
ECU has been reset, AFM cleaned just before that, stock return BOV. Can't hear any air leaks. Ran a error check on the ecu it came up thst everything was fine.
Afternoon whores...the SS went to the repairers today...lets see how long they take to give me an incorrectly repaired car back.
5 weeks. Will sit at quoters for 2 weeks for the assessor to look at.
love the positive approach their Mikie.
Hopefully, it will be fixed soon. Just keep communicating with them.
I'm yet to find someone who has had a car repaired by them and be happy with it and not be f**ked around, my hopes that it would be different for me were dashed when they initially sent me to a place that doesn't do imports...
^this. If you don't ring them they will not contact you. The only time I got any updates on my repairs was when I rang just car and got the repairers number.
Greg, I called that dude today about white rb30 - he sounded fully sic and tells me it's not modded, but genuine Tomei rb30 cam, valves, springs and retainers. He said High Octane got custom Tomei stuff for builder.
So what really happened is they bought a wade cam and a set of letter punches, stamped Tomei on the cam and charged him 4 times the price they bought the wade cam for, because he is a silly kebab.
Haha thanks. Just waiting on today to see if the skyline is ready. I owe zac so much for working on it
You still owe him for that maltesers incident, stop being slack.
Luckily I worked 500m from the assessors, they got to see me everyday as my patience wore thin
  • Like 1
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
