Mugabetown - Whoretownin' At It's Worst.
howdy peeeps
how is everyone? i have been off the radar for a long time now for various reasons. hope to get back to normal soon. have a tumor in my skull that needs to be drilled out.
ps. anyone know much about the 300ZX Tommy Karia Edition?
My friend had that done when we were in High School. At least they found it, all the best for the procedure, I am sure you will be back at it in no time :)
howdy peeeps
Not good to hear benno, best of luck.
RE the 300ZX, I know that it'd involve just as much engine out.
well it is a lot better then drilling for CSG. I cannot believe how retarded our government is to allow it to happen on our soil. One only has to look to the devastation caused by fracking from the USA. Checkout a doco called Gasland by Josh Fox if you haven't already seen it.
The lure of the revenue is too great.
don't mining companies have an obligation/ responsibility sanctioned by the Australian Government to return the area drilled or mined to an environmentally safe and natural state or this not reinforced as well as it should?
My personal view? I don't beleive there is a strong enough knowledge of the risks to create appropriate conditions to manage those risks.
I would love to hear/ learn more about this mate.
Maybe over a beer (or two) one day :)
Teins have arrived
Inb4 queries about Sydneykid bilstien package - is on hold due to other financial commitments and current coilovers are well and truly f**ked
You didn't consider doing bushes and ball joints first?
  • Like 1
yeah, slowly acquiring the parts Grego (already have the rear subframe bushes from whiteline)
Once I post a pic of my current strut/ coilovers you will understand
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
