I have just done a single turbo conversion on my GTR so I have some stock parts for sale
Parts are from a 2000 R34 GTR with 93,000kms
Available for pick-up or post at additional costs
Pick-up in Kallangur, North Brisbane
Call during standard working hours 8am - 6pm on 0488083818 or PM on here for any additional info
More to be added in the coming days.....
BNR34 Stock fuel pump and lines $60
BNR34 Fuel rail / Injectors / Stock FPR $250
BNR34 Stock Turbo's, Manifolds, M's pod filters, Standard AFM's, All pipes (Inc a custom Stainless twin 3" into 3 1/2" front pipe)
Turbo's are in perfect working order and made 257kw @ less than 1 bar on my stock BNR34 the day they were removed (Dyno sheet can be provided) $1200
BNR34 Stock Suspension, removed @ 90,000kms
Perfect working order, no knocks etc $200
https://www.sau.com.au/forums/topic/431362-r34-gtr-parts/
  • 3 weeks later...
Once again all parts are off my 2000 BNR34
AFM's $100ea or $150/pr
Cams & Cam Gears $100
ECU $250
FRP Front Bumper Vents $200
Rear Bumper Lights $200
Turbo's, Manifolds, Dumps with stock actuators & O2 sensors $400ea or $700/pr
Custom Stainless twin 3" into 3.5" Front Pipe $300
M's Pod Filters $50
Orange Side Fender Indicators $20
Orange Front Indicators $25
Twin Turbo Pipe $80
Items located North Brisbane, Prices are for Pick-up
0488083818
Cheers
Noy
https://www.sau.com.au/forums/topic/431362-r34-gtr-parts/#findComment-7042415
  • 2 months later...
Bump, New Prices
Rail & Injectors $200
Standard Fuel Pump $50
ECU $200
AFM's $100/pr
FRP Bumper Vents $100
Fog & Reverse Lights $100
Turbo's, Dumps & Manifolds $500/pr or $300ea
https://www.sau.com.au/forums/topic/431362-r34-gtr-parts/#findComment-7155081
  • 4 weeks later...
AFM's & Stock Suspension have gone..
Items still available
Fuel Rail & Injectors $200
Stock Fuel Pump $50
ECU $200
Bumper Vents $100
Fog & Reverse light $100
Twin Turbo Pipe $50
Additional Items
Stock 34 GTR Rotors F & R $100
Momo F1 steering wheel & boss kit originally came in the 34 GTR $100
Personal steering wheel & boss kit off 33 GTR $50
https://www.sau.com.au/forums/topic/431362-r34-gtr-parts/#findComment-7176422
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
