I was hoping that someone can help me.
I want to get some info on the re4ro3a auto (came standard in 300zx z32 & Nissan patrols)
The r33 rb25det auto is a re4ro1a. The 2 autos are the some ,but in the re4ro3a everything is bigger (so I've been told). The skyline bellhousing will bolt up & so on.
The person I spoke to about this auto said that, he can modify the valve body to 4gaers on the shifter, manual shift, & also a trans brake if I wanted
How many other mods is there for this auto ,is there any big pans for it
Has anyone pushed this auto to its limits, at what hp
Anything that anyone knows or heard about this auto, would be very helpful
Thank you for looking.
https://www.sau.com.au/forums/topic/431723-auto-mods-for-big-hp/
  • Replies 53
I've been looking on the Internet all morning, and I found a website that said ,
Re4ro1a was used for medium duty vehicles (r33 skyline, steaga)
Re4ro3a was used for heavy duty vehicles (300zx twin turbo, Nissan patrol gq-gu)
I also found the gear ratios for both (same ratios) ,& the 300zx had 3.692 diff gears ,which suits me
I would not be surprised if there are few to no physical differences between those two transmissions. There might be slight differences in the width or material spec of friction materials, or there might be line pressure differences designed to make it better able to haul around a heavier car.
Remember that in terms of manual transmissions, the big VG30 manuals are essentially the same gearbox as the big RB manuals. They're all about the same strength. It's trivial things that change, like overall gearing, the bellhousing, shifter location.
If you phone MV automatics in Adelaide they will help out.
Have you got a phone number / website
I also found out that they hold about 4litres, the guts of the auto is a bit wider & longer. The pump is also bigger
Folly built they can hold about 1000hp (so I've been told)
try 14 litres and your closer mate.
Let us know how you go with the auto
What you doing about the converter (standard , hi stall)
Will be around a 3500 stall. Mz will re work the std converter to what will suit your purpose included in that price
Auto was sent off today it will be back in 3 weeks to be installed and then some fun. Full manual valve body etc push button overdrive and push button lockup clutch for highway driv
So theres no automation on the lockup clutch at all? If you stop the car you stall?
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
