For those that missed it, last weekend Martin fainted under a 180kg front squat
Then nine.msn get hold of the story
http://www.news.com.au/lifestyle/health/remove-bar-from-windpipe-then-squat-guy-faints-in-gym-fail/story-fneuzle5-1226725940365
Then Fox FM get hold of it
http://www.fox.com.au/shows/fifi-and-jules/blogs/2013/9/what-happens-next/
They ring me, and I tell them Marty is fine, in fact he front squatted 180kg on Saturday............and I filmed it. They plead with me to post it, so I just did
Wow, all this over a missed front squat
https://www.sau.com.au/forums/topic/432271-martin-nguyen-becomes-famous/
Martin has copped no shit, he misses a front squat every Saturday in the gym.
Martins claim to fame?
He has all the GPC teen WR in the 82.5kg class
He has all the junior GPC WR in the 82.5kg class
He has the Open Men GPC WR for deadlift
I have lost count of his National Records
He is sponsored by Ironedge, features on the cover of their catalogue, and inside
His best lifts, raw, are 255kg squat, 160kg bench and 290kg deadlift. He is 20 years old
  • Like 1
  • 5 months later...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
