Hi guys
I need your help. I'm in the middle of my build and wanting to know if anyone has used Tomei procam 270 with 10.8mm lift in/ex on their rb26/30 build?
It's the full mac daddy build and going into my pro drift car.
Bottom end is JE pistons 8.2:1, nitto I beam rods, Ross balancer, tomei pump etc etc.
I need to know if these cams will be beneficial for drifting where I am chasing mid to top end power (on off throttle a lot) also need to know if they mite be to laggy?
I think you can also get 260duration cams with the same lift?.any better??
Thanks in advance!
Will take a while to fill those cylinders - why did you go for such low compression?
Re the cams - have a read though the "what cams would you choose" thread below.
I think you might know Joe Kyle? He said to stay with that standard compression ratio. I wanted more but he talked me down ? lol
I would've thought too big. For a drift car you want instant snappy power. With such low comp and big sticks I think you'll struggle to achieve that unless you've got a small super responsive turbo which then defeats the purpose of the big cams cause you're not going to achieve massive top end anyway! With that comp you will be able to push big boost into it but that will only make it a slug until it hits boost then you'll have a huge top end which wouldn't suit drifting.
I would think Poncams would be a lot more suited if you even bother with cams at all.
If it's not too late I'd bump comp up to 9.5:1 and get a mid sized turbo (presume single?) so you've got an engine that makes power straight away then a turbo that comes in not too soon after.
What power are you chasing?
Rb30et is 7.8 to1.
OK just looked up the RB30 PDF and that says RB30E is 8.2:1 and the RB30ET 7.1:1 (although the exact figure would depend on what twin cam head you were using) but whatever that's going back a few years - today you would want better than 9:1 or even more if using E85
sorry I wasnt clear, that is with the sohc head it is 7.8:1 .
ok I've got some 260 10.25 inlet and 270 10.8mm ex, talked to a few tuners who suggested that duration. Also Ive got JE pistons so i think they only come in 8.2:1 or 9.1? Too late anyhow they've been ordered :wacko: Will post results when all together :bunny:
Too late then!
The lower comp should give you a huge top end when you chase it later on (with big boost) I just hope it does the job for you in the meantime.
Maybe you can just hold it at 6000 rpm minimum with some mad anti lag system and it'll be perfect!
Too late then!
Yer thanks mate, I'll post up a video when it runs, let you be the judge :)
  • 10 months later...
  • 3 weeks later...
what happened with the info/vids, everytime I get interested in something it just stops, I must be a JINKS :(
  • 2 years later...
Old thread! Sorry boys been a while since I have been in the threads. For those wanting to know on results which may help them on their build etc etc
Car made 550Kw on e85 @ 21psi on A Holset Turbo.
Specs;
26Head (cams stated previously)
Nitto I Beam & JE Pistons
ID2000s with e85
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
