Drop saws such as Brodo's (cold style) have an advantage in that they remain true to the cut that you are making as the cutting disk is much stiffer, were as if the bandsaw blade losses tension it can wander and no longer make a true cut. The slow cutting of the Brodos can lead to them fouling the cutting teeth if use with aluminium based alloys, not such an issue with the bandsaws. Drop saws designed for aluminium use use a different tooth pattern and a higher cutting speed than those for ferrous materials.
Your options are either cut off drop saw which will do the job but annoying that you have to clean each cut up alot whereas bandsaw does a pretty clean cut and not much if any clean up is needed. I personally have been using drop saw but will be changing to a bandsaw when I get the money.
$100 cut off droppy is all the average guy needs for backyard fab, you can do alot with them and awesome value. they are only a minor pain when cleaning up 50 lobster back cuts, but you can get pretty quick at it with time. Ill spend up big on a bandsaw when i run out of other cool tools to buy..
I use all three, definitely the Brobo if you can find a cheap S/H one. I also use the $1200 H&F bandsaw for larger sized pipes, great for 4 inch or larger.
I use the friction saw very rarely. It doesn't cut straight and the clean up time is horrendous. If you plan to use one, you will need to invest in a linisher to clean/flatten the cut.
Is this all because alloy has to fit perfect to weld or you get holes n stuff?
I know with steel you wouldnt need a linisher to get it that perfect for welding.
I just got a cheap mig welder and havent tried alloy yet, so im curious.
If your fusing with stainless as most ppl do for cooler piping yes you need a perfect fit to have a nice weld.
tbh.. my cut off saw cuts very straight, 3mm blade (maybe just lucky), only clean up i do is a quick linish and its ready for a perfect fuse with the tig. i posted a few pics in the lobster thread, all that is with the cheap saw.
Yeah I also agree aswell my cheap shitty drop saw cuts pretty straight just have to linish with a grinder and die grinder and they fit spot on.
never had one catch pipe, i dont usually do much alloy pipe work though. I always thought it was a bad idea to cut alloy pipe with a drop saw, the alloy clogs the disc. Dont know how much truth to it and i havent really done much research of my own but was told this can cause the disc to explode in extreme cases.
opps read you use an alloy cutting disc, never mind if you have one of those :)
Edited by r32gtrs
Don't know what horizontal you had in mind, the ones I've used only had variable feed set up for steel and would be horrid for bends, a variable vertical would be my preference if you only had one choice (along with a selection of tooth count blades). Typical stainless tube cutting, I use a friction drop saw as first preference. A disc linisher is very useful for squaring, don't know how good the hobby grade H&F ones are? If all else fails, hacksaw and snips have saved the bacon many times and a realistic option if you're only doing a few!
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
