Drop saws such as Brodo's (cold style) have an advantage in that they remain true to the cut that you are making as the cutting disk is much stiffer, were as if the bandsaw blade losses tension it can wander and no longer make a true cut. The slow cutting of the Brodos can lead to them fouling the cutting teeth if use with aluminium based alloys, not such an issue with the bandsaws. Drop saws designed for aluminium use use a different tooth pattern and a higher cutting speed than those for ferrous materials.
Your options are either cut off drop saw which will do the job but annoying that you have to clean each cut up alot whereas bandsaw does a pretty clean cut and not much if any clean up is needed. I personally have been using drop saw but will be changing to a bandsaw when I get the money.
$100 cut off droppy is all the average guy needs for backyard fab, you can do alot with them and awesome value. they are only a minor pain when cleaning up 50 lobster back cuts, but you can get pretty quick at it with time. Ill spend up big on a bandsaw when i run out of other cool tools to buy..
I use all three, definitely the Brobo if you can find a cheap S/H one. I also use the $1200 H&F bandsaw for larger sized pipes, great for 4 inch or larger.
I use the friction saw very rarely. It doesn't cut straight and the clean up time is horrendous. If you plan to use one, you will need to invest in a linisher to clean/flatten the cut.
Is this all because alloy has to fit perfect to weld or you get holes n stuff?
I know with steel you wouldnt need a linisher to get it that perfect for welding.
I just got a cheap mig welder and havent tried alloy yet, so im curious.
If your fusing with stainless as most ppl do for cooler piping yes you need a perfect fit to have a nice weld.
tbh.. my cut off saw cuts very straight, 3mm blade (maybe just lucky), only clean up i do is a quick linish and its ready for a perfect fuse with the tig. i posted a few pics in the lobster thread, all that is with the cheap saw.
Yeah I also agree aswell my cheap shitty drop saw cuts pretty straight just have to linish with a grinder and die grinder and they fit spot on.
never had one catch pipe, i dont usually do much alloy pipe work though. I always thought it was a bad idea to cut alloy pipe with a drop saw, the alloy clogs the disc. Dont know how much truth to it and i havent really done much research of my own but was told this can cause the disc to explode in extreme cases.
opps read you use an alloy cutting disc, never mind if you have one of those :)
Edited by r32gtrs
Don't know what horizontal you had in mind, the ones I've used only had variable feed set up for steel and would be horrid for bends, a variable vertical would be my preference if you only had one choice (along with a selection of tooth count blades). Typical stainless tube cutting, I use a friction drop saw as first preference. A disc linisher is very useful for squaring, don't know how good the hobby grade H&F ones are? If all else fails, hacksaw and snips have saved the bacon many times and a realistic option if you're only doing a few!
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
