sounds exciting, should be online by the time im back home from the gym tonight. can't wait.
ok so i have barely (i.e. not at all) investigated what is available online...can we somehow decorate our house (if we get one)? Like spray paint our logo over it?
also racing(fighting) the evo/sti guys, i think we might need some kind of organisation at least to find where they are so we can trash their clubhouse meet up with them
  • Like 1
i really wanna get digging into the editor - it looks fairly easy to use, although all i've seen is from the video about making missions etc.
I'll need to have a good look into what's available, but what kind of missions are people looking into doing? I'm keen on races and heists, but does anyone want to do team deathmatch etc?
i down for abit of everything. to be honest, im least likely to do car races...... but ill give em a go.... i wanna try and do as many as the 300 online missions as possible.
I'm all for completing missions with the SAU crew and will support where necessary.
However, I really can't wait to cause havoc to the other crews. Build up relationships/trust and when they least expect it, f**k them up :)
Good ol' GTA - letting us do things we wouldn't normally do in real life since the 90s.
damn straight...... i dont really care what you do.... but if the other members are getting hammered because of your mistakes, you may find a horses head in your bed.
Excellent! I would be disappointed if it was any other way.
Massive nights in strip clubs anyone?
This is a must!
Just a warning, these kind of nights will end with a murderous rampage in the strip club. Anyone is free to join in on said rampage.
  • Like 1
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
