I got no mic and some little 14 year old was bagging me out. Nearly smashed my controller because I couldn't have a go at him.
ahhahahaha well fark me seems like my ps3's wirelss has decided to conk out, or something else wrong with it, i cannot get it to connect to the net and thus i haven't even DLed the online update yet....fark me.
no biggie though, i don't mind waiting a while until the online gets ironed out a bit...i just hope my wireless somehow comes back or else im gonna be pissed...and buy a ps4
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
