Strange because when I was playing last night it popped up saying "89Cal joined SAU"
Yeah that is a bit odd.... I joined a few days after the crew was created.....
Blew some money on my car today, its to hard to save for properties :P
Also, my PSN name is CAL096 if it has caused any confusion. Its not a 17 year old imposter
Edited by 89CAL
you meant the GTA races? they are retarded lol. spent both races trying to figure out how to use the pickup weapons. trying to finish a race in a supercar with no rear tyres... kill me now
I think LordUmadbro and NISMO_R31 (or whatever) are due for promotion. good players, doing the crew proud
thanks dude - will check em out :)
anyone know how to use the weapons you pick up in GTA race? google only brings up the f**king usual results "how to make your dick hard on gta 5 and level up quickly" "10 reasons why this website is shit (gta 5)" etc.
f**k console people. seriously.
Press down L3 :)
Yeah, it seems console peasants have problems in making actually helpful topics ;)
Hey guys can you please post your ranks in here.
A few people aren't sharing their ranks via the social club so it's hard to tell if you are an active member or not.
I'm playing around with the hierarchy because a fair few people have joined but don't play online very often
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
