If anyone loses there car because they didn't pick it up from the impound in time, you can do an insurance claim and get it back. Just a heads up because I didn't think about it straight away.
My car got impounded and I respawned on a beach where someone kept killling me, was 12 vs 7 kills by the end I think, pretty annoying. Had to start a mission to get out of there.
yar i think it's easier to just wait till it gets crushed then claim it by insurance,  near impossible to steal it back out of the impound lot
Hey?
Ive got my car back heaps of times from there. Jump the back fence, hop in car, Wait at gate, run from cops
I have a garage around the corner so I just run there
stole a fighter jet from the airforce base and tried to get away but they come after you hardcore, so got killed by another jet.
respawned.
then one of the jets who is obviously got nothing to do now just landed next to me in the hills.
i walked up kicked him out and took off.....free flight time in the fighter with no stars....loled
had like a good 4hr session playing with a guy called joe. Was plenty of fun driving round killing everyone and hanging out of cars shooting..
only gripe i have is if you get close or run past ur crew member it automatically switches and kills them or hits them.....kinda blows
hard to get the jets and get away with so many stars though.
Easiest way I found, as soon as you hear the jet lock-on after you take off, L2 (brake), hard turn left or right, (R2) full throttle... The missile(s) will miss you and then just fly straight. After the Jet misses me, is never catches me.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
