i mean craig that the series two light wouldnt work on the stock series one bumper. Naturally bonnet, bumper and grill would have to be changed. So i was right.
What you said and what you meant are 2 different things buddy.
I am unsure as to why you quoted my Mark, but your post was correct and quite clear I thought.
Alex had it the wrong way around. S1 headlights on an S2 M35 will leave a gap. The reverse is not possible without the front bar, grill and bonnet change.
G35= ugly!
Yahoo auctions japan= easy to get but with freight and dealer commission ect.... Ends up being way expensive for the panels.
Not really, following are total prices inc shipping/fees etc. The bonnet cost me $110 landed. Headlights $390 for both (in perfect condition). Front bar (Axis S) $~220 landed. Axis Grill was a bitch to get although I finally found one and ended up costing me $130 landed.... all pickup from Import Monster warehouse of course.
The extra was to get the bonnet repaired and painted ($200) and the front bar painted ($100) as I am no spray painter!
All was done over months and the waiting for the right items was frustrating to say the least, but what can ya do?
Ooo nice work :) Do you wanna make 2 other?? :)
Send me private message and let's see what we can do. Where are you from?
Nokonzok.... Very nice conversion. Just one question, can you see the original globe holes in the reflector after the projector is fitted?
I'm thinking of doing something similar as it would cost too much to change to series2 hlights especially with all the extra panels required.
Thanks
Justin.
I think we have little language barrier here, what do you mean by globe holes?
In the original reflector there is 2 holes for the low beam and another hole for the high beam (someone correct me if I'm wrong please) and I am assuming you had to drill a single hole in the middle of the reflector for the bi-projector. So I'm wondering if you can see the original holes in the reflector?
I can do this conversion easy. I've done it before on my bike cbr1000rr. I put bi-xenon projectors with white halo and red demon eyes. With Audi style LEDs at the bottom.
  • 1 month later...
Hello, Guys!!
reading this forum for years, would be pleased to help its habitants!
here, i hope, i will show all about M35 S1 to S2 front conversion.
First, we have nicely converted AR-X and AXIS
now just AR-X: (owner - OlegARX, nismo-club.ru)
video
S2 bonnet on S1 car
Result
more photos here http://www.nismo-club.ru/forum/index.php?showtopic=37609&view=findpost&p=1062191349 and here
http://www.nismo-club.ru/forum/index.php?showtopic=94350&view=findpost&p=1062189182
The next part to change is front part of dust protector (we call it locker)
The final point is difference in color and material of widebody parts
also i'we seen pics of S1 headlights in S2 car
hope you find it useful!
  • Thanks 1
Hello, Guys!!
video
S2 bonnet on S1 car
Result
Welcome mate. Your wagon in that colour, with those wheels and how clean it is, its awesome. I did a stagea swap on my V35 and that black underplastic like yours doesnt fit and neither do the inner gaurds. So annoying!
Edited by Howaitonaito
this car is not mine, it's owner is OlegARX (real name - Oleg =) )
my one wears unique front with original S1 headlights. We fitted AERO with AR-X
http://www.drive2.ru/cars/nissan/stagea/stagea_m35/erop/
  • Like 1
I basically am stuck with the non flare bumpers unless i can get the rear flares to fit a sedan. Id love a axis nose
You could have one, but would have to use a series 2 axis car. One of them doesn't have the flares, Axis or Axis S.
i would need the axis series two bonnet and chrome strim, headlights and bumper and id be set. But not a priority right now alex. Priority is turbo maxima.....i mean skyline
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
