Proudly Presents:
Import Monster SAU-Vic Deca Motorkhana ROUND 4 of the 2013 CHAMPIONSHIP
When : Saturday 9th November, 2013 (7:30am)
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $95 non members $85 members
Max Entries: 50 + Reserves
Entry Form & Supp. Regs: ENTRY FORM
Event Schedule: SCHEDULE
The top 3 finishers will receive a Penrite 10 Tenths Racing pack, to the value of almost $200!!! :woot: :woot::woot:
ENTRY FORM IS REQUIRED TO BE PUT ONTO THE LIST. PAYMENT IS REQUIRED TO STAY ON THE LIST.
  • Please fill out your entry form clearly and in full
  • If you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Reon Staprey Disclaimer'
  • All withdrawals will be refunded after the event. Refunds will not be given after 5pm Sunday the 3rd of November.
  • A reminder that anyone who does not have a licence (Cams or AASA) must bring with them, filled out and with $50 correct change, this form:
AASA LICENCE FORM
  • The insurer of the event (AASA) has issued supplementary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
  • This also impacts passengers, as they must wear a helmet prior to entering a competition vehicle.
  • A fire extinguisher is required by all entrants and needs to be bolted to the vehicle. Screws or cable ties are not acceptable.
  • Please re-read the supplementary regulations before entering the event.
  • GATES WILL BE OPEN AT 730AM. Cars need to be scrutineered before drivers briefing at 9am sharp.
  • Grouping requests: If you have anyone that you would like to be grouped with send me a PM and I will try to accommodate.
Please support our sponsors:
Import Monster Pty. Ltd. Factory 3, 6 Wigan Road Bayswater VIC 3153 (03) 9008 0031
Penrite Oils
Entry List: as of 4/11/13
Entrant # Name Car
1 Import monster #1
2 Import monster #2
3 Leon Stapley 180sx
4 Ryan Bell Sil80
5 Jake Lowry S14
6 Simon Henman 33GTST
7 Evan Boyack Fiesta ST
8 Josh Davey S15
9 Michael Glover XR8
10 Daniel Jones 200sx
11 Josh Hindle 180sx
12 Aaron Tan S15
13 Huy Tran Stag
14 Jett Benson 180sx
15 Mark Ryan VT2 33GTST
16 Paul Mason Soarer
17 Luke Ryan 200sx
18 Jason Carey 33GTST
19 Michael Hill 34R
20 Min Chan Elise
21 Robert Dyer 33GTST
22 Thomas Gilver Polo Gti
23 Rhys Yeomans XR5
24 Lindsay Polkinghorne S15
25 Chris Wilshire XR5
26 Robert Amenta 33GTST
27 Paul Morris CO BRZ
28 Katie Dever CO BRZ
29 Andrew Thai GS300
30 Phillip Tran 180sx
31 Joshua Simpson 180sx
32 Andrew Hindle 180sx
33 Matt Hindle XR6T
34 Russell Cunningham Sil80
35 Ben Felgate S14
36 Kieren Robinson Sil80
37 Christian Palmieri XR5T
38 Kurt Thompson 200sx
39 Matthew Femino Sil80
40 Andrew Tanti 86
41 Johnathon Comer evo6
42 Travis Eva evo6
43 Sean Power R32GTST
44 Alex Anderson S14
45 Anthony Femino R33GTST
46 Minal Doolbah M3
47 Elliot Kerby E30
48 Matthew Robins E30
49 Chris Lack R32GTST
50
Putting "TBA" is fine, as long as you bring the card along on the day and show it to Bec during Driver Sign In. If you don't have the AASA card on the day, you can bring along a completed AASA Club Race Licence form and $50 on the day if you still want to compete.
If its getting within a week of the event and you still haven't received your card, I'd be calling AASA and they might be able to send you a cover note letter so you can still complete.
Entered...woop. Haven't seen you in awhile Russ, be good to catch up..Sarah coming up too (shock horror)
Yeah man. Will be good to see you 2.
DORIIIII all the way! R32s are staying home resting for SAU nats :-)
Better get to fixing it!
Yeah dori time again! Better get 2 sets of tyres sorted from thewheeldeal! Yeah 32 still needs fixing for SAU nats. Will be fun driving that again!
NSW invasion?? :cheers:
My aasa license has expired 30/09 but I have rang winton and they are emailing me through the form to renew it, what do I put as the number and expiry date?
Just noticed that mine expired on the 30th- Sept too.... :closedeyes:
You called Winton? Thought you have to call AASA?
Aasa is based at winton.
57664235 is the number.
Faxed my forms and paid.
I may change car's though if that isn't an issue, see how I go for time getting my xr8 ready to enter
Cheers for the info Josh.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
