The point of it is that Nissan Japan sold the GTR within the existing "Gentlemen's Agreement" that said no manufacturer would release a car with more than 205kW (or 206, or 207 or 208, depending on who you listen to). The restrictor was put in the boost control system to set the boost to a level that would stay pretty much within the gentlemen's agreement, but was trivial to remove and make GTRs close to unbeatable on the street (which was one of their highly desirable aims, of course).
The ECU will happily run the engine with that much boost, but it wil be richer and more retarded than if it was tuned properly. Rich and Retarded is a little safer on the engine. Well, the richer part certainly is. Retarded can be less safe sometimes. But I digress. Yes, for 15 years after the release of the R32 GTR people would simply pull that restrictor out and just drive it round. No problem.
So I think I took the right line off and looked in the hose and can't see anything, how far down will it be? I'll upload a pic maybe to make sure I have the right hose. Maybe previous owner already removed it
The boost gauge just goes to the top 7+
On a side note/question I started my car this arvo after being parked for 1 hour maybe and it just stalled then I started it again and the idle was
Real rough like it was going to stall but I kept the revs up a bit, this has also happened once before any ideas what it may be?
Once driving its fine both times have been on startup
Hmm could be a loose earth or even dirty AFM
Is there any particular mods like a vent to atmo BOV
The only way a bov would effect the car on idle would be a seriously rooted spring, and the problem would a hell of a lot more noticeable during boost, in for form of no boost.
Did the splutter only happen after stalling? Or does it just randomly happen on startup?
Yer it is randomly on startup, it stalled then when I started it again it spluttered a bit and started dropping revs but I gave some aceleration to bring the revs up for a couple of seconds then it was ok held fine on idle
factory bovs are slightly open at idle due to the manifold vacuum acting on them,(and don't leak under boost) so I would assume some after market bovs could be the same.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
