Lol don't listen to the self proclaimed king of lag either! Go with 9's forget about 7's and 5's! :D
Everyone knows how much fun it is losing to a stock WRX at the lights unless you're spinning your car to redline in the 1st 3 gears!
Your incorrect proclamation not mine.
If anyone with - 5s has issues with rexxys, you are shit drivers probably the same people that need - 9 or 7 to launch off the line properly and make up for your lack of skill. :P
  • Like 1
Another question. What cams are avaliable as a drop in replacement just trying to figure out my next move I've got power fc 550cc injectors apexi induction. Adjustable cam gears zorst not sure on size or anything tho may have standard dumps and fronts not sure yet and I just purchased boost controller not fitted yet and just thinking what else I can put in relatively cheap ish under 1k before I get the boost controller in and dyno'd and dialed in. I'd really like to hit 300+ kw.
I'm at 245kw atm
Well I know it has jasma cannon roughly a 3" system to the cat I just string measured it one day. But turbo to cat not sure. And I figure if the cars getting dyno'd I might as well make it worth it. If not cams and zorst what else would you suggest
Edited by 0zhiph0p
I was thinking e85 now that she's not a daily but I'll have to get bigger injectors again and pump I guess.
But other than exhaust cos I'll check over the weekend to see they may have already been changed. I bought it with mods zorst cam gears and intake. what would you all suggest.
Edited by 0zhiph0p
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
