Hey guys,
Got a few things I'm giving away or selling for cheap....
1. GABS Front strut bar (R32 GTR / GTST) - $30
2. Boot lip (R32 GTR / GTST) good condition - $100
3. K&N Pod Air Filters (x2) - $50 (only used for 1 week)
Part number: RR-3003
4. Stock exhaust manifold (RB26) - free
5. Hi Octane Oil Catch Can (NEW) - $250 (selling online for $400....see website below)
http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=67_74&products_id=1635
6. Left rear tail light assembly - $50
7. Stock blow off valves - free
8. Blown alternator (RB26) needs TLC - free
9. Centre rear light - free
10. Car jacks - free
11. Exhaust (cat back) - $200
12. Speedo cluster (R32 GTR) - free
13. Stock valve springs, cams and cam gears - $50
Either local pickup (Brisbane) or postage at buyers cost
Cheers
K Si (0412 962 639)
https://www.sau.com.au/forums/topic/432947-assorted-items-cheap-or-free/
Hey mate, let me know postage on the cluster to 2154. Might be keen on the catch can too.
Hit me on 0419170619 for the fastest reply.
Hey mate,
Postage costs sent to your mobile.
What a nice fellow giving away free stuff. Heads up though - I don't think the alternator will be salvageable, it looks like when it blew up the pieces formed into something resembling a starter motor :P
  • Like 1
LOL! Was thinking isn't that a starter motor?
LOL thanks guys...
was definitely rushing putting the sales thread up
LOL thanks guys...
:) No worries mate. A small mistake in your ad is an insignificant negative when you are giving stuff away - thanks for doing it. By the way I PMd you in regards to the exhaust manifolds.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
