Hey guys so i haven't had this car for long. Its a 1994 s1 r33 gtst with a built motor td06 turbo etc etc.
i did a compression test last week numbers came out good, and then i did a wet compression test with adding oil in each cylinder individually. I put about half a oil bottle cap worth for each cylinder.
After that put everything back together, then started the car and alot of white smoke came out which im guessing is normal from the oil in the cylinders. I took it for a spin around the block and white smoke was still coming out but less and kept getting less. i then took it in the garage and turned it off. didnt touch it for a week.
So after a week i came to start the car and it wouldnt start, it cranks but wont turn on. Fuel lines have pressure but just wont run.
i thought maybe my spark plgs are stuffed from the oil so put new ones and still the same
I have split fires, i pulled one out put a screw driver in it and put it near the head and no sparks, so i know there is no power going to my coils. Note this is a s1 r33 with the ignitor on top of the motor at the back.
So what i dont understand is the car was turned off and not touched for a week and this happens, obviously nothing has been touched..
SO i know its a power issue, anyone can help or give advice??? PLSS
btw ecu is a haltech pro plug and play
https://www.sau.com.au/forums/topic/433039-skyline-built-not-starting/
Have run into this issue in the past with s1 rb lol exact same issues.
If you can get your hand in a stock ecu plug it in see if it will fire.
That's what it ended up being for me the ecu buggered out on me.
Checked fuses ?
Checked fuses ?
I couldnt find any relevant fuses. The ones in the boot are just for lights etc the engine bay fuse box any particular one i need to check?
ill hookup the stock ecu tonight hopefully not that as I like my haltech :(
I'd check the fuses in the engine bag again..
In particular anything related to engine cont... Or fuel pump related .
Can you smell fuel as in is it definitely getting fuel when cranking ?
My battery is fine.. but I know I dont have spark.. I can hear the fuel pump and the fuel hoses have fuel in them but not sure if injectors are actually injecting or not. Anyway to find out? Cant really smell fuel
As said did you forget to reconnect the earths?
Are you sure you have enough battery voltage?
It is very common for aftermarket ECU's not to pulse ignition drivers when they have low voltage. Sounds simple regardless of what it ends up being.
There is a ignition coil distributor in the S1 skylines. Check the wiring on that and make sure this part is working. I had same problem few years ago and that turned out to be the issue.
+1 coil pack ignitor on S1's fail easily.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
