You sneaky rat ! YOU UNEDIT WHAT YOU SAID ! NAOW!
Thursday - thanks guys. She is going through this time !
I had a temporary empathetic moment so withdrew original post. It will not happen again :no:
It had something to do with the length of this thread and related to your 1kFred and the speed at which your vehicle travels ....... :rolleyes:
  • Like 1
wait so you didnt end up putting i the rest of the bolts for the stock airbox?. i was late dude i only put in enough to secure it. Donno I maybe wrong but arent you're only allowed one intake mod either pod or intercooler? lemme know if you're using the stockies too. might come pick them up for spares for Wakey.But if you are dont fret
I didn't know I was bolting it in haha I had plans for putting the stockies on today at robs - I seriously lack tools to which I need to purchase some form of car kit like you have. Also, as I've said before - I was not marked down for the intercooler / Pod filter. I'd rather get done for a pod filter and nothing else becuase of the easy change over. Atm, my car is struggling to have a defect (Yes I know, it's easy to find a defect - but at a cheap cost?). Plan is to force them to pick the airbox so all I have to do for the re-test is change an airbox, if it does not get pinged well, lucky me / they'll probably find something else. Besides, the holes do not line up so bolting it in will be missing bolts regardless.
In short - my car will not be passed first go - but I rather them find an easy fix to ping me on then saying "oh, it appears your car has chassis damage - go get it fixed" nekminit $3k later.
Edited by RosieR34
This is incorrect.
Not sure who made this up, could even be a NSW rule but it does not apply in ACT and shouldn't in Australia either for Skylines. Skylines (R32-R34) had factory fitted front mount intercoolers (GTR model) so it is not a modification, just a replacement part.
This is incorrect.
1 cold air intake is a Vic law. However the "replacement" is defined as legal here yes?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
