Hey all
currently installing injectors to my gtr.
It currently has Sard 800cc changing to bosch 1000cc for e85.
I didnt release you had to make the injector and plug.
Can any one tell me (look at pics below) how the extension and filter fits to the injector? which way around.
and any hints to put the plug together and get the old one off?
also how pedantic do i need t go with emptying the fuel tank to get the old fuel out? i was going to remoe the tank completly but have since seen how hard it is to remove...
Help??
https://www.sau.com.au/forums/topic/433248-injector-install-fuel-tank/
the extension just clips over the top to make it the same length as your stock injectors....the filter fits in there somewhere i guess
like this
you only need the cap if the injector is shorter than the ones already in it...alternatively you can not use the caps and just lower your fuel rail to fit....looks neater this way...depends on your setup though
to empty your tank just run the pump...run a power wire to it, or just short it across the relay so it pumps and put a jerry can at the fuel line....
the filter should only fit properly one way, I just fitted ID1300s and the extension/adaptors already came with the filter fitted but I had to fit the plugs, you need a W crimping tool to crimp the pins properly
I just cut the old plugs off, put a hose on the top of the filter into a bucket then run power to the plug at the top of the tank and pump it out
the other thing I did was break off the little black ring below the O-ring as I found that was hitting the manifold before the O-ring seated properly
will going from 800s to 1000s make that much of a difference, couldn't you just bump up the fuel pressure
not sure...thought it would only fit one way...buti would think it flows through the gold bit fist and out the other end...does it sit in the top of the injector maybe?
for the plugs just cut the wires and crimp them in...doesnt matter which way around they go
I just bought plug adapters so I could still use the old plugs if I ever got defected. The adapter plugs were like $8 each. It worked a treat. Also from memory the gold bit of the filter was as the top and filter went down into injector.
This is the reason I pre-install the filter in the adapter and solder the pins to make up the plug adapters on the kits I sell. It keeps my customers from having any of these difficulties.
The filter drops into the adapter from the top, then tap it down with a plastic hammer.
Don't cut the old plugs off unless they are damaged. Just use plug adaptors.
Thanks for the help guys.
finished it off sunday.
Took out as much fuel as possible then flushed through 10 ltrs of E85 through it.
Took out as much as possible again then filled it to the brim.
Now have to wait on a tune!
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
