Read this thread - ultimate RB "pull hard" setup, make numbers in the range of GT35R peak power but spooling similar to the smaller GT30 range turbos:
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/
+1 for lithiums post. HTA turbos are weapons and will give you the best of both worlds. Will give you 400rwkw and the same response as a gt3076.
You'd be mad not to have a look basically
I disagree with both these clowns :ph34r:
LOL kidden, HTA or GTFO!
Was just trying to be helpful, was Garrett based and a lot of people don't know there is a bigger world than Garrett who have been all but left in the dust. But point noted, I have meant to have given up on trying to be "helpful" on these forums - just got a brief burst of enthusiasm for this place after finally actually meeting some SAUers... as you were :action-smiley-069:
Asks about Garrett offerings, gets advice on every other manufacturer but... :P
Well technically Garrett make the turbos with the HTA wheel :P So sort of got it...
Hhahah
I get the same thing.
Left in the dust is a little excessive, I love my GTX and the results are excellent imo. Keep your HTA fanboi speeches for the impressionable boys in the FP thread. Considering you all talk about them continuously I would find it hard to believe someone hasn't heard of FP, Precision or BW for that matter.
I think Garrett is still king of reliability in most peoples minds... for good reason. If that means they are a little slower in their design rollouts and test their turbo's for longer, I am all for it. I have a Precision 6766 on the bench at the moment, not sure I like how thin the compressor blades are. Hopefully they haven't gone too light weight just to beat the competition...
No need to sook about being 'helpful on these forums', everyone else is here for the same reason. If you don't like people having opinions that differ to yours, better stay off the interwebz.
Hi all
I read some comments here and it looks like people prefer GT30 for around 290-320rwkw power. GT30 will come on boost harder in the mid range. It looks like a more efficient option on paper.
One thing I don't understand is why would someone want harder pull in the mid range when it will create more problems with traction unless are on 3rd gear. I have rb25 with GT35 312rwkw and I have problems with traction on 2nd with 265s and shimmed diff. I've driven similar car but with a smaller turbo and it had even less traction.
Correct me if I'm wrong, since I'm new to this. If I floor it at ~3000rpm it will pull hard almost instantly and easily break the traction on a smaller GT30 turbo compared to GT35 which pulls from ~4500+ but has smoother transition from no boost to full boost.
I have read many threads about this but not many people are looking at it from this angle
Cheers
Hi all
Cheers
You'll find your traction control switch at the end of your right leg; when traction starts to break, lift right leg slightly.
Also on most good ECU's you can do boost by gear and just have less boost in 1st and 2nd.
No reason you can't just lift off slightly though...
Maybe of interest, I found this helped with controlling boost on my car:
http://www.gktech.com/index.php/v2-s14a-s15-eccentric-throttle-wheel.html
It will work fine on an RB25DET. The standard wheel opened the throttle quite a lot with little pedal movement, where as the GKTECH one is the opposite, ie a smooth logarithmic opening of the throttle, where 50% pedal may only be 30% throttle opening. (not sure about exact numbers)
Its good for peaky responsive turbos.
the best action ive had was with a GTX3076, 4000rpm's = Hammer time, 1st and 2nd at WOT =Black lines layed for 50meters which is f#$k yeah feeling.. 3rd= hold on
If you can do this then you know you got a wild ride, the rest is up to you and the tyres, suspension and right foot control, but personally this has set the bar for me... and now disappointed with anything less :(
Go with the Gt35. They are the bomb diggity.
They also have plastic cage bearings afaik, where as the GTX has steel cage. Hence the reason the old diesel designed GT35's have a higher failure rate. It's one of the Garrett turbos I wouldn't recommend.
Go with the GTX3076 imo for a similar power figure and quicker spool.
not wrong here. The GTX3076 is awsome fun. i love it!
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
