Hi guys I've been home injured for a while so I decided replace the piping in the car with the blue silicone pipe connectors i also cleaned the AMF and blocked off the Bov any way I took it for a drive today and I noticed that a few times I shifted up there was a bit of a pop keep in mind I haven't driven the car in a month and a half. I checked all the pipping and there was no leaking sorry in advance if I posted in the wrong place :)post-99784-13823496495387_thumb.jpg
https://www.sau.com.au/forums/topic/433739-r34-misfire-issue/
Unblock bov.
Yeh I was thinking that mite be the issue I don't know why I did it probably because I liked the sound until I herd it on my car then suddenly I'm not such a huge fan can you recommend a good bov that's going to be legal but better then stock thanks again mate :)
Kind of pointless but if you really want to change bov, use a gtr one.
Because the GTR bov's don't have the 4mm bleeder hole I think. Anyway, it isn't hard to tap an M5 thread into the hole and grub screw it for the same effect. The stock bov will work fine at up over 300kw with it blocked...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
