Hey all,
Looking at some Varrstoen es1 rims (BBS LM replicas) for my gtt, but I can't decide whether I want 18's or 19's.
My current setup is 18x9.5 +15 all round, with 255/35. The fronts sit pretty close to flush, while the rear guards definitely have room to accommodate a wider rim and tire.
**The most aggressive setup offered in 18's are: 18x10.5 +12
These will sit 16mm further out than current rims, with the inset having 10mm less clearance. (basically around 5mm poke at the front, rear's pretty flush I'd assume)
**The most aggressive setup offered in 19's are: 19x11 +12
These will sit 22mm further out than current rims, with the inset having 16mm less clearance. (around 11mm poke at the front, slight poke at the rear)
Seeing as the rims have a step lip, this usually makes them appear smaller, which is my argument for going with 19's, but that said I wouldn't be able to lower the car any more, and I think they will foul on the coilovers.
18's allow me to lower the car slightly to eliminate wheel to guard gap, and I'm a bit more confident on this fitment clearing everything.
OPINIONS AND COMMENTS!
https://www.sau.com.au/forums/topic/434208-18-or-19-inch-rims-on-r34-gtt/
I would go 18's on a GTT, 19's will be too hard to fit, The right rim will look nice whether it is 18 or 19.
You were the one with pumped guards yes? If the most aggressive offset isn't enough poke for you I would just run a hubcentric spacer, it will only be ~10mm anyway?
Yep, pumped rears, gtr fronts.
I've been thinking 18x10.5 +12 with a 265-275/35 on the rear. I'm sure this will look fine, but yeah if needed I'll run a bolt on.
Fronts will need some camber if I go a 265/35.
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
