You don't use a hand brake at all for this ;)
Exactly what I was going to say. If you got a VQ35DE then use the torque to flick the back out. Just did a slidewize day last Saturday and only used the hand brake for parking!!!
Using the handbrake on a wet skid pan is a strange concept. All about weight transfer and throttle control. I am keen to have a go in the V36 auto... Just for kicks... I have no ability whatsoever so be gentle...
Didn't realise that it was a wet skid pan. Should be fun then. Was thinking that it was going to be very difficult to execute decent runs with a dry skid pan, no clutch and no hand brake. :P
:thumbup: it looks good!
Is it still AWD in the video? I'm interested in doing a skid pan day in mine and just wanted to know how they go if not in a RWD configuration.
I think AWDs go alright but want to grap traction and go. But they can definitely be skidded.
yeah was still in awd , didn't seem to cause it any problems and was just happy sliding, but as others have said, you do pick up speed alot more than the rwd boys, half the fun i guess
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
