hey guys so im doing an rb26 swap into my 350gt and im not that smart about turbos so I was wondering what would be the best setup to get atleast 500hp but also minimal turbo lag. so I don't know if I should go for a twin turbo set up. or a single turbo. I was looking at a gtx4202r for a single turbo setup. any ideas?
https://www.sau.com.au/forums/topic/434479-rb26-swap/
  • Replies 41
You dont want lag BUT you are looking at a GTX and in a 42 frame? :/
https://www.sau.com.au/forums/topic/434479-rb26-swap/#findComment-7093151
Regardless of which turbo, this is still predicated on the assumption that he will take out a modern 3.5 litre aluminium V6 with a hell of a pedigree for a rattly old f**king RB that can trace its roots all the way back to the early '70s.
Now, I like my dirty old RBs......but you'd be a fool to think that dollar for dollar you would get anything better out of a transplanted 26 than you would keeping the VQ and slapping a turbo and some management onto it. You wouldn't even get "cred" for it as far as I am concerned. It's already been done, therefore it's not even "different". Just foolish.
https://www.sau.com.au/forums/topic/434479-rb26-swap/#findComment-7093454
