May take you up on that Mitch. Base on the youtube vids I've seen and the documentation it looks pretty straight forward. I'm just making up the external map and wideband interface looms now.
I can't imagine Haltech would have left any surprises for me. Out of the box it should control the fuel pump speed and send the correct TPS signals to the Attessa right? Ive seen lots of other people have issues with these two simple things... Edit: Other ecu's of course... Wolf/vipec etc...
Edited by GTRNUR
High/low fuel pump control is hard set at 5% throttle opening (from memory). The TPS follower for the ATTESA 100% works as per factory, as does the injection duty signal to the MFD.
The pre-loaded base map should be enough for you to get started with. Just make sure you load the calibration for your MAP sensor, set your TPS limits, enter your injector characteristics and deadtimes and away you go. Set base timing (i like to lock the CAS all the way clockwise) by enabling the ignition lock and adjusting the trigger angle. Dont forget to set the engine capacity, and if you're running an ethanol blend of fuel without a flex sensor, deduct ~33% from your injection flow rate to allow for the fuel density difference. :cheers:
Not necessary, it just connects to Inj1. The MFD does the rest.
If you were able to program up an 7th injector channel, it would need to be configured to have the same output pulse width as all the other injectors. Also, you would need to put a load on the output, or a pull up resistor to +12v so the MFD would be able to read the variable PWM square wave.
Sorry no dyno time yet.
The Haltech is in now. It idles and revs. Didn't get a chance to drive it anywhere though, nor do anything but do the basic setup on the weekend.
With any luck I can take a day or two off later this week and spend some time on the phone with Mitch.
AI tell me my surge tank is still 2+ weeks away as well.
  • 2 months later...
More changes are still in the works. I've replaced the entire fuel system again after being talked into going down the E85 flex fuel path. So bigger injectors, more pumps, bigger fuel lines, external surge tank and bags of fittings...
It takes for ever to get parts up here too. Pay for overnight and it arrives 3+ days later.
I've yet to source and wire in a flex fuel sensor, and I've got locate a fuel cooler to mount behind the diff too.
The interesting news is that I hope to be getting Mercury Motorsports to come to Cairns to do the final tune and setup of the car. If anyone can get it to produce a good final result, I think they are certainly capable of it.
  • 1 month later...
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
