BC for sure, I had them in my last R34 & put them in my current R34. Went standard 8/6 & on full soft I dont think they are much stiffer than the king springs that were on before. Full hard really is HARD!
It's not listed as a Type 1 Hooning Offence AFAIK / IIRC so it wouldn't result in an impound..although, for the paranoids:
"Dangerous operation of a motor vehicle" is a Type 1 Offence...and a very broad offence at that...open to interpretation whether an excessively low car qualifies....:P
You'd have to be pretty unlucky to get done for something like that...
Edited by fusion07
Cheers mate, does anyone know if your car is below 100m and your just randomly Encountered by police can they impound your car or is it just warning/defect?
AFAIK defect. Adjustable height coilovers are also defectable even if you are above 100mm. 100mm is whilst the car is under full load.
I have lowered my car leaving a finger width gap between the tyre & wheel arch & the body is still well over 100mm off the ground, I think it was around 150mm. I dont have a body kit on it.
My exhaust however at its lowest point is less than 100mm off the ground. Still not sure if they measure from the lowest part of the car or from a structural part.
Lowest point mate. Get a bracket made to bring it up?
  • Like 1
Iirc the height adjustment threading can be spoiled/locked so it's impossible to go below 100mm, then mod plate issued. Most people wouldn't dare to spoil their expensive coilovers though so no one does it. I've been driving with bcs for 4 years now, only got pulled up once and the dude just said it's too low and drove off, mind you this is in an s15 that was slammed to kingdom come lol. My current caris much mmore sensibly set up and no attention attracted so far. If you don't plan to slam it then good chance they won't care, but it's your choice in the end.
Edit: left out an important detail never been through a roadside defect station ever. If you got stopped at one then that would be a different ballgame...
Edited by fusion07
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
