Hi guys,
Have for sale full set of suspension (coilovers and shocks) and all mounting hardware.
Drummond Motorsport DMS50's
They are currently on car and will be taken off when sold.
(so if you are local you can come see and feel on-road)
They have DMS 'Targa Spec' spring rates and valving. 9kg front, 5.5-6kg rear. Springs are tapered progressive type.
(This pic below is not mine - just pulled from Interweb - but this is what they look like (but maybe dirtier at the moment :) ).
$2300 ono.
Edited by R32 TT
  • 3 weeks later...
  • 1 month later...
Yep these are no problem at all on the street. I think the valving in them is the reason for that. They are 'firm' due to medium-high spring rates but pretty good at ironing out those little bumps and are never really harsh. Being Targa spec you can imagine they have to be an extremely good all rounder.
Also DMS are fully rebuild-able - so if ever you wish to tune them up a bit or alter valving/spring rates etc you can.
The only reason I am changing is that I am trialling some AST 5200's and being looked after very well by the distributor. Sort of a sponsorship deal if you like.
You don't see too many AST setups on GTRs that I am aware of so will be interested to see how they perform.
Amazingly - I still have these... Is no one aware of DMS and how good they are??
Good value for money guys - surely someone is looking for better than average suspension for both street and track duty?
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
