Has anyone tried these new momo tyres? Momo Outrun M3. >>> http://www.momotires.it/en/summer-tires/outrun-m3.html
I'm hesitant in buying a pair (for the front) because I cant find a single review.
They've only just come into the market.
treadwear 280
Why do I care? Because they are priced so ridiculously cheap. I'm hoping price is not based on their quality, but rather because they're new to the market.
  • Replies 52
I wish i knew as well. It's either these or Nittos for me, and the Momos are priced very cheap at the moment because they are new.
We might have to be the first to test because i really need 2 for the front! I will be going to get them next week somewhere off of the M5 before the tunnel.
I just got a pair fitted this morning. $250 for the pair in 225/40/18 at St.George Tyres in Arncliffe. The guys there are pretty damn helpful.
I replaced 235/40/18 Falkens with them. The Momo dont come in 235 and the 245's would have scrubbed.
I didnt want to go down in size, but when they measured the tread width, it turns out the 225 Momo are actually a touch wider than the 235 Falkens.
So they look and fit just right. No stretch now, compared to the Falkens.
No strange vibrations or anything of that nature that you would see immediately with a crappy tyre. The tread pattern looks good. The tyre quality seems good. Not that its saying much at this stage.
Interested to see what they handle like in the wet.
They are definitely quiet (if that's important to you), and surprisingly comfortable.
I'll report back here after ive had them for a while.
update. yes it does say 'made in china' on the tyre in microscopic lettering.
ive been driving in the rain, and after-rain wet slick road surfaces over the last 2 days. momo m3's on the front.
these tyres grip very well in wet conditions.
there was no sign of any slip or aqua planing.
the front gripped really well in the bends, corners, and straights.
obviously i'm not pushing them to their limits in the wet on the street.
but so far, i'm really happy with these tyres, and for the price, they seem unbeatable.
hopefully they hold up well over time.
No complaints here!
they were fitted at 35psi, but felt a little 'dull' in respect to feedback. so I'm running these at 40psi (which i usually do up front anyway).
theyre definitely comfortable at 40 though. They absorb the bumps well. Still quiet, from what i can tell over my engine/exhaust noise anyway.
feedback is good, response is sharp enough. grip is great.
  • 3 weeks later...
after using these tyres for a while now. I'm going to say they are fkn brilliant!
grip grip grip! comfort. excellent response and sharp turn-in.
ive pushed these fairly hard in the wet, dry, cold, hot, dusty (ahh sydney weather!)
better than ku31. def better than mid range falkens. better wet grip IMO than nitto 555's.
that's all i can compare them to. Oh and better than achilles, obviously.
i'm impressed!
That would be ace, I've had my Kumho 39's 205 55 16's on for about 9 months now and rate them highly, especially in the wet. Their only flaw is the sidewall could be stiffer, as sharp changes of direction feels a little mushy, but that could be because of the 55 profile.
maybe increase pressure? the r33 has a shitload of weight over the front wheels, so i always run 40psi for the fronts in 18's. not sure about the r32 with 16's.
and at lower pressure, these momo's can feel a bit mushy too. but right now, they feel fine, and not at all uncomfortable.
  • 4 months later...
yeah i have an update!
these tyres still feel great. not a single complaint from me.
still grip like new. feel like new. dont seem to have deteriorated much, if at all.
very pleased.
i only wish they came in more sizes, like 235/18 and 265/18.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
