Hi guys,
Got 6 brand new still in packaging Sard 540cc injectors suit RB25/SR20. Come with fitting kit (o-rings, collars, plugs etc) Bought as a precaution and no longer needed. Paid $810, asking $550.
Also a brand new still in packaging genuine Bosch Z32 AFM with Tomei plug. Paid $330, asking $250.
Can MMS photos as required, or inbox them on Facebook as they're "stuck" on my phone and I can't upload them to the forum from my phone?
All items brand new, located in Warrnambool Vic.
Contact me on here, or 04 3774 51 FOUR SEVEN
Mods please delete my other thread regarding the injectors.
Cheers!
The numbers on top of the injectors themselves:
1001-87090
Kit part number (number printed on the paperwork with them)
63560
Edited by blk94r33
RB30 injectors are top feed with hose-tails, RB25 injectors (these items) are side feed, so no they won't fit to my knowledge?
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
