Hi,
Most will probably say what the f**k are you doing.
but yes, i do want to convert my rb26dett to a 26de.
Reasoning: just finish the build on my 32gtr, and i want to enjoy that. however, i still have a standard rb26 sitting around....along with a standard 72' datsun 240z...so that should clear it up abit more.
I dont ever plan on selling the s30 and im tossing up between keeping it original l24 or going rb. my reasoning towards the rb conversion is that since i dont plan on selling it and keeping the L24. i might as well go all out...
What kind of things would need to be done to convert the standard rb26 to a na screamer. im awayre of the pistons to up the compression. but any thing else?
https://www.sau.com.au/forums/topic/435033-rb26dett-to-rb26de/
imagine this...
a RB26DE, with super high comp, with HKS V Cam (optional if you want any low end), stupid duration cams, 6 flutes and a redline at 10k in a 240Z...
brap brap brap brap brap brap
but say if you skimmed the head all the way to a 10:1 surely it wouldn't be "that" bad right?
10k redline N/A ITB would be sick.. and stupid as long duration cams, but of course will need some form of VCT to give it more poke down low.
http://forum.r31skylineclub.com/index.php?topic=104694.0
/\ Here
from the topic
IMG_4531.jpg?t=1230424228
What it has:
Adaptronic ECU
1 Bar Haltech Map Sensor
Nismo Pressure Plate
Chromoly Flywheel
Cushioned Button Clutch
Series 2 R33 GT-R Head
Camtech Cams 290 degree (seat to seat), 263 degree (50 thou), 11.5mm lift - Biggest for RB26 from Camtech at the time
Adjustable Cam Gears
Supertech Valve springs
Supertech Valve Stem Seals
Bosch 440cc Injectors
Nitto Intake and Exhaust Gaskets
Nitto 1.8mm Head Gasket
Head Stud Kit for RB30DE/T setup
Running very close to 12:1 compression
RB25DE Pistons (slightly shaved)
Mahle Motorsport Ring Set
Balanced Rods
Tomei Oil Restrictors
ACL Race Main Bearings
ACL Race Big End Bearings
Crank has been grub screwed
Crankshaft oil pump drive collar
R33 GTS-T Oil Pump
R32 GT-R Water Pump
Ross Tuffbond Harmonic Balancer
Lewis Engines Race Sump 7.5lts Gated
Splitfire Coilpacks
Rebuilt HR31 GTS-X radiator
Head to Sump oil/air separator
Tuned Equal Length Hurricane Extractors
2.5" Mandrel Bent Exhaust
3" Stainless Steel Cat
Hotdog
Mega flow rear muffler (straight through style).
topic property of DMN NA R31sc.com
Edited by GH05T
i would honestly rather keep the Z n/a. and what better engine for it than the rb. i dont really care about the power, my gtr is there for that. Im all down for the screaming high revs bouncing off trees when i go for a drive. i think it would be better if i just na a rb26dett rather than buy a 1 of 200 autech rb26? last i heard they were goin for 6k...IF you can find one. LOL. rb26/30 na would be affordable.. jsut swap over some parts n vwoahlah. (ok maybe not that easy) but within reach. ive been trying to source a autech rb26....not happening.. =\
i pm'd him. hopefully he replies. im hoping to go to his workshop since he is fr sydney, and check out his work. his build showed it got 170rwkw... which isnt much. but from a FR car that weighs 1000kg and an engine that can rev over 9k. mmmmm
Why not RB25DE NEO ?
Great option.
It's never going to be a power house like a turbo motor. But this would be a great option. Cheap motor, set it up using headers and ITBs. No need to even open it, besides cams. Enjoy the noise and cruise in a awesome sounding and looking car.
Leave the power to the R.
DO IT
skimmed the head because the 8.5:1 compression will suck donkey cock, bring it to like 9.5:1 or even more if the pistons don't foul the valves.
then mod the intake plenum and install 6 flutes, bring the rev limiter up to 10k (I'm sure it will spin easily to that safely as it's now making 1/2 the power)
then whack on some retarded long duration cams...
brap brap brap brap hahah
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
