I am in the market for a new ecu for a 2j motor.
Noticed haltech have a new ecu coming out towards early next year but unsure if I can be bothered waiting for it.
I have noticed ViPEC have a new i88 ecu which looks quite good.
Anyone have any feedback on this particular ECU ?
https://www.sau.com.au/forums/topic/435341-new-vi-pec-i88-ecu/
Vipec is basically a Link and i have been running Links for years.
Awesome ECU. Numerous motorsport options which are all unlocked, they only require a small cost motor sport harness be purchased, options of up to a 7 bar map sensor, runs well with the Ross Balancers crank trigger system
I see no reason to not use one ;)
Does this new Vipec have built in Knock sensing capabilities?
I heard they might be coming out with this a while ago, would be the only benefit over my link G4 that I have at the moment.
Although link have realeased G4+ (Not in plug-in version yet from what I've seen) so it might end up being a similar thing
Apparently, unsure how good or how different it is from the previous model.
http://www.vi-pec.com/ecus/i88
ndividual Cylinder Knock control, with support for two sensors. Knock control is user definable with flexible settings to allow precise knock control adjustable by ignition angle
Yeah that is literally the only thing I dont like about the G4 is that there is no onboard knock sensing.
But I suppose it wont be hard to update in the future. Hopefully it can use the stock knock sensors. I kept these on the engine even though the Link doesnt support them, in the off chance that they would work later on
E85 - built in knock sensor :D
another happy G4 customer - first flex fuel conversion, first non-HKS electronics V-Cam control - pretty stout piece of kit :)
can't go wrong with the link/vipec's
G4 is brilliant, just depends on how many items you want to run off it. Flex fuel, crank trigger, wide band, oil pressure, fuel pressure... You run out of inputs very quickly.
I used to run a vipec. trying to sell it and upgrade to a haltech. Better tech/product support.... that and there's only 1 vipec dealer out here lol and his tunes take me into the 10 and 9.8 AFRs...
Edited by NismoSTune
So a couple of features on this ecu that makes it a little more favorable to the haltech is the knock control and 4 temp sensor (have to add resistors to the haltech!).
However, mapping is a bit better on the haltech and i know i am able to change a voltage setting for the tacho output...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
