hey guys
this morning i went to go for a drive but i had a feeling i should check my fluid levels before i do so
and i did, i found a lot of oil in my coolant, we pressure tested the radiator and it held pressure well
very small drop in pressure after 15mins, and also did compression test which came back ok.
am i looking at a suspected blown head gasket here? or are there other places where the oil could have
gotten into the coolant from?
Hmmmm 32 GTR so it wont have the oil cooler/heat exchanger. Thats one of the spots where it can happen on 33 GTS-t's
Off the top of my head, I think headgasket is the most likely culprit.
Really depends what you want. Stock will be easier only for the fact that all the coolant lines etc are already there in place. An aftermarket cooler will be a bit more work because you will have to make the lines up etc, and its in a bit of a shit spot to get to. But then your guaranteed to not have a cross contamination between oil and coolant
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
