Formula 1 is to make another attempt to ban tyre warmers in 2015.
Previous efforts to introduce a ban have been scuppered because of safety concerns, amid worries from drivers about racing on cold tyres.
But as part of a raft of changes proposed for 2015, the FIA announced on Thursday that all forms of tyre heating devices will be outlawed.
The FIA has also ratified that the minimum weight of cars will increase by 10kg to 701kg in 2015 - which should help alleviate concerns that heavier drivers are put at a disadvantage.
http://www.autosport.com/news/report.php/id/112250
idiots.. didnt pirelli state they need to be within a hot and cold temp range to not explode?
Eric Boullier is set to become McLaren's new Formula 1 team principal after quitting the Lotus team.
Following intense speculation about plans for McLaren following Ron Dennis's review of the organisation, Boullier has resigned from his position as Lotus F1 team principal with immediate effect.
The Frenchman, who has done an impressive job at Lotus despite financial constraints, is now favourite to land the job at McLaren.
Lotus has confirmed that its owner Gerard Lopez will be its new team principal for 2014, and will share responsibility for running the outfit with co-chairman Andrew Ruhan.
Although the loss of Boullier will be a blow to Lotus, the Enstone-based outfit remains hopeful that it has a strong commercial and managerial platform going forwards.
Lopez said: "Lotus F1 Team has never stood still and we head into what promises to be an exciting 2014 season with an innovative new car, new partners and a new management structure at Enstone.
"Great things have been achieved over the past years and we need to continue this momentum.
"We thank Eric for all his hard work over the past four years and we are confident we can continue to fight as one of the top teams in Formula 1 over the seasons ahead."
Lotus is missing next week's first pre-season F1 test, but plans to unveil its new E22 car at the start of the second test in Bahrain.
McLaren is launching its own 2014 challenger at 12pm GMT today (Friday), although it is unclear if it will announce any plans for Boullier.
http://www.autosport.com/news/report.php/id/112254
well f**k me i didn't see that coming..
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
    • I don't know what you should expect with an LS, but the oil pressure sounds terrible, sorry. As for the brakes, you can get fade from the pads not just the fluid, although generally that feels like a wooden block not doing anything while fluid feels like an oh shit there is no pedal so you can generally tell. What pads are you running front and rear?
    • Went over my datalogs on a whim and noticed a worrying combination of events. High RPM High Temperature Low Oil Pressure Knock Retard I bought some 10w-60 because I actually think this will be better going forward given track temp is 125C and 10-40 will actually be thinner in those environments. I know I had a leak but it's not entirely sure how much pressure loss can be attributed to that. The knock retard does correlate with all of the above. When it's not present oil pressure is higher. And by 'low' I mean at 6800 RPM the oil pressure was recorded as low as ~35psi pretty constantly. Which is obviously very not good. I'm hoping that thicker oil that ISNT LEAKING will result in a bit more pressure when I need it. Also in the last session I got a very spongy break pedal. I bled the lines as the car is on jack stand right now with the wheels off and I noticed... no air in the lines? Maybe the tiniest bit of tiny frothy bubbles for the first 0.1 seconds of bleeding the whole car? The breaks did come back to me after I backed off (and felt fine driving normally). Doesn't appear to be any leaks anywhere that I can see. Any thoughts on that?
    • Solution, run shitter tyres. Let wheel spin be your weak link 😛
