Seeing as we are halfway through the race now, what are everyones thoughts on the racing?
I can't really see any difference between this year and last years (apart from the car in P1 not being a RB). It's still all about the DRS zones.
Terrific drives so far by Kevin and Dan though. Rosberg is doing alright as well I guess :P
Alan Jones: the man you turn to when you can't find anyone with a personality to do the interviews....
Yeah the interviews were a bit lame because of that hey.
big kev huh
dude is a real baller
EDIT: but in saying that, bottas was the star of the show today, he certainly has them big balls
bottas was the best out there by far, other than his dodgy rim :)
Dan has been disquallified
