So who's tipping what for the Malaysian GP?
I'm quietly thinking Mercedes are going to have an engine failure of some sort, something about Hamiltons interviews since Melbourne make it seem like he/they are not entirely confident with the engine he will be using
If Rosberg's has the same potential issue then being the engine that has done more km, there might be a problem with his car
Or they might walk away with this one again, who knows.
Will get to see some real power comparisons with the long Sepang straights at least. See how the Ferrari stacks up to the Merc, I think the Renault is behind so we will get to see that for sure or not as well
Hoping Ferrari have made a step forward, hope Kimi has a better run
Rosberg's worked which is a good start and maybe an indication it will continue to work. They only get five (?) per year so you would hope one gp hasnt knackered it.
Predicitng Ricciardo will continue to dominate his fragile team mate.*
Hoping the Caterhams qualify nowhere near the Williams.
*May have gone somewhat early with the domination call.
My money is on a very strong weekend by Williams. They generally go alright around there and then fall off the face of the planet until the end of the year.
Will be very interesting to see the racing as there are plenty of overtaiking opportunities at Sepang
Well you can always hope. Problem with teams going better than they should is they almost invariably find some way of stuffing it up. eg Bottas in the wall or it rains and they have no wet weather pace or some other random reliability thing that screws a good weekend.
Wish I could pocket a dollar for every time multi 21 gets trotted out this weekend.
f**k. Like I said, NOONE in here is going to decide what the outcome is. Its pointless arguing like this.....
Just wait till the f**king appeal and then everyone will know
f**k. Like you said, NOONE in here is going to decide what the outcome is. Its pointless discussing it like this.....
Just wait till the f**king race and then everyone will know
:P
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
