UMERICA---FARK YEH!
Should be interesting. Building a team up from scratch...real question will be whose engine? Honda? Surly not Fezz. Have they ever supplied good customer engines?
It's rumoured to be Ferrari powered.
So whi is a gambling man. My money is on RBR winning...real test of the independence of the tribunal
..oh by win I mean found not to exceed the fuel flow limit...from there how the politics plays out will be interesting. Reading some various resports to the letter of the law RBR shoudl be ok...but the intent and spirit...and egg on FIAs face...umm...will be interesting
Stefano Domenicali has reportedly resigned as Ferrari team boss with an official announcement coming late Monday
He has been a spectacular influence over the last few years, imagine if his scowling face hadn't been there to urge them up to the level of also rans.
"We respectfully submit that the most effective way to ensure that Red Bull do not flount further instructions from the FIA is for this court to recognise the severity of their infringement and to impose a further sanction upon them which is to be suspended for the rest of the season, so that they are acutely aware."
Farking Mercdes. They got their QC straight out if their undergroung SS training school.
Come in RBR!
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
