UMERICA---FARK YEH!
Should be interesting. Building a team up from scratch...real question will be whose engine? Honda? Surly not Fezz. Have they ever supplied good customer engines?
It's rumoured to be Ferrari powered.
So whi is a gambling man. My money is on RBR winning...real test of the independence of the tribunal
..oh by win I mean found not to exceed the fuel flow limit...from there how the politics plays out will be interesting. Reading some various resports to the letter of the law RBR shoudl be ok...but the intent and spirit...and egg on FIAs face...umm...will be interesting
Stefano Domenicali has reportedly resigned as Ferrari team boss with an official announcement coming late Monday
He has been a spectacular influence over the last few years, imagine if his scowling face hadn't been there to urge them up to the level of also rans.
"We respectfully submit that the most effective way to ensure that Red Bull do not flount further instructions from the FIA is for this court to recognise the severity of their infringement and to impose a further sanction upon them which is to be suspended for the rest of the season, so that they are acutely aware."
Farking Mercdes. They got their QC straight out if their undergroung SS training school.
Come in RBR!
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
