Interesting you say that. I am now reading on forums etc that Rosberg turned up his engine in Bahrain and in Spain Hamiltion turned it up to keep him behind. Everything I have read from Lower and Toto suggests that it was only Hamilton that played with engine spec against teams instructions. In Bahrain Rosberg was able to do so as it was his strategy to do it at that part of the race...so wasnt disobeying the pit wall in doing so. Seems Lewis saying Noco did the same thing in Bahrain is what people are remembering....and that is a statement out of context
Does anyone have a link that confirms Nico disobeyed the pit wall in Bahrain?
http://en.espnf1.com/f1/motorsport/story/160127.html
However, Wolff revealed that the tension dates back to the epic battle between the two in Bahrain where Rosberg was using engine modes that Hamilton was not and then Hamilton did the same when the pair were racing in Spain in two weeks ago. Wolff played down the significance of the two incidents, but said it had added to the tension in Monaco and would not be allowed in the future.
"In the last couple of races we had some little fouls left and right, and in the team we made sure this is not happening again," Wolff said. "The most obvious bit is you can play around with the engine modes, so this is not happening ever again.
Cheers, that suggests that Rosberg may have disobeyed the pit wall. Other quotes suggested that Rosberg was allowed to be in that engine mode and Hamo didnt understand why Rosberg was allowed to use a different setting...seemingly associated with Rosberg running the more conservative tune when on the harder tyre.
I recall thinking that was odd as if my memory serves me right comign down to the last laps in Bahrain Rosberg had used more fuel so didnt really support he had been in a more conservative engine setting mid race
yeah ive heard different things too, i think in the f1 telecast they talked about the engine mode being one that they are never to use.... but who knows....
in other news
http://en.espnf1.com/f1/motorsport/story/161097.html
'murica....
Yeah certainly sounded a little but suss. Every other time they'd choose to come out last so that they can shut the car down early if they aren't going to be beaten so as to save the tyres, etc.
It's going to be an interesting run into turn one. I think that if homo can get in front into turn one he will lead from start to finish. I don't think britney has the overall pace that homo does, he just managed to turn it on for 1 lap
yeah definately he was so close with a couple of mistakes, so yeah rosberg's gonna have to pull something out of his arse....
hamo has said going out last was prob not a good idea getting caught up in traffic....
maldanado reprimand for not putting his steering wheel on...
hopefully williams can have a good race!
Disappointing for Williams. I think Perez was at fault but Massa showed today that he is past his best and really should have got the job done as soon as he arrived on the bumper of Vettel. Cant help but wonder the 2012 Williams would have had if they kept Rubens and this year if they had someone like Romain
Funny to see Button in 4th...the guy is quick for one stint in 6
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
